eMMC performance testing
搜索替代
5,085 次查看
nirmalluhana
Release: Yocto-Morty (4.9.51_GA)
Board: i.MX8MQ EVK
I have tested eMMC performance on iMX8MQ EVK board using dd & hdparm and I observed that read speed is approx 135-140 MB/s and write speed is approx 20 MB/s. While referring eMMC datasheet it mentions that eMMC performance as below image.
So, what is the reason I have got that much low performance?
Nirmal
3,981 次查看
igorpadykov
Hi Nirmal
slow emmc write issues were already reported on web, like
Re: slow eMMC write speed — Linux MMC Development
In particular below presentation emphasize on write performance issues for this type of media.
https://elinux.org/images/4/41/Linux_on_eMMC-_Optimizing_For_Performance.pdf
As for i.MX8MQ, it has many modules and complex architecture with bus arbiters,
so it is not possible to provide max. performance characteristics for every module.
You can increase performance for one module, but that may affect others.
General answer is provided on
USB 3.0 Raw Throughput
4 回复数
3,982 次查看
igorpadykov
Hi Nirmal
3,981 次查看
nirmalluhana
Hi Igor,
Thanks for your quick support. I understood the reason why it was happening.
Nirmal
779 次查看
jagsgediya
Hi @nirmalluhana What was the reason for slow performance?
593 次查看
chen-wust
Now I also want to improve the read and write speed of emmc. Do you have any progress
