I have done the installation part on a SD-Card as described and shown below. But I just get until a Starting Kernel ... message, no further.
Does anyone know how to fix this?
Thanks in advance
Juergen
my Hyperterminal Bootsequence is:
U-Boot 2013.04 (Sep 19 2014 - 17:56:15)
CPU: Freescale i.MX6Q rev1.2 at 792 MHz
CPU: Temperature 45 C, calibration data: 0x5a74db7d
Reset cause: POR
Board: MX6Q/SDL-SabreSD
I2C: ready
DRAM: 1 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In: serial
Out: serial
Err: serial
Found PFUZE100! deviceid=10,revid=11
mmc1 is current device
Net: FEC [PRIME]
Normal Boot
Hit any key to stop autoboot: 0
MMC read: dev # 1, block # 2048, count 12288 ... 12288 blocks read: OK
MMC read: dev # 1, block # 20480, count 2048 ... 2048 blocks read: OK
## Booting kernel from Legacy Image at 12000000 ...
Image Name: Linux-3.10.17-1.0.2_ga+g33597e3
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 5260744 Bytes = 5 MiB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 18000000
Booting using the fdt blob at 0x18000000
Loading Kernel Image ... OK
OK
switch to ldo_bypass mode!
Using Device Tree in place at 18000000, end 1800ebac
Starting kernel ...
and I don't get any further.
Everything is based on the package: fsl-L3.10.17_1.0.2_iMX6QDLS_Bundle.tar.gz
what I did before was:
U-Boot > setenv loadaddr 0x12000000
U-Boot > setenv fdt_addr 0x18000000
U-Boot > setenv fdt_high 0xffffffff
U-Boot > setenv bootargs_base 'setenv bootargs console=ttymxc0,115200'
U-Boot > setenv bootargs_mmc 'setenv bootargs ${bootargs} root=/dev/mmcblk0p2 rootwait rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24'
U-Boot > setenv bootcmd_mmc 'run bootargs_base bootargs_mmc;mmc dev 1;mmc read ${loadaddr} 0x800 0x3000;mmc read ${fdt_addr} 0x5000 0x800;bootm ${loadaddr} - ${fdt_addr}'
U-Boot > setenv bootcmd 'run bootcmd_mmc'
U-Boot > saveenv
U-Boot > run bootcmd
and
#!/bin/sh
DEV=sdc
BOOTLOADER=u-boot-imx6qsabresd_sd.imx
KERNEL=uImage_imx_v7_defconfig
DTB=uImage-imx6dl-sabresd-hdcp.dtb
#Copying the Boot Loader Image, offset=1k
sudo dd if=$BOOTLOADER of=/dev/$DEV bs=512 seek=2 conv=fsync
#Copying the Kernel Image and DTB File, offset=1M
sudo dd if=$KERNEL of=/dev/$DEV bs=512 seek=2048 conv=fsync
#DTB, offset=10M
sudo dd if=$DTB of=/dev/$DEV bs=512 seek=20480 conv=fsync
also by hand:
#sudo fdisk /dev/$DEV
#sudo mkfs.ext4 /dev/${DEV}1
#sudo mount /dev/${DEV}1 /home/juergen/tmp/mnt
#sudo mount -o loop -t ext3 fsl-image-weston-imx6qdlsolo.ext3 /home/juergen/tmp/rootfs
#cd /home/juergen/tmp/rootfs
#sudo cp -a * /home/juergen/tmp/mnt
I received from command output:
733+1 Datensätze ein
733+1 Datensätze aus
375488 Bytes (375 kB) kopiert, 3,37769 s, 111 kB/s
10275+1 Datensätze ein
10275+1 Datensätze aus
5260808 Bytes (5,3 MB) kopiert, 35,8851 s, 147 kB/s
93+1 Datensätze ein
93+1 Datensätze aus
48045 Bytes (48 kB) kopiert, 1,03537 s, 46,4 kB/s
so everything seemed to be ok.
Solved! Go to Solution.
For those who run into the same problem.
I changed my setup script to:
#!/bin/sh
DEV=sdc
DTB=uImage-imx6q-sabresd-ldo.dtb
#DTB, offset=10M
and now it runs.
#!/bin/sh
DEV=sdc
#DTB, offset=10M
and now it runs.
Good work Juergen Vorbach,
works fine... :smileyhappy: .... DTB=uImage-imx6q-sabresd-ldo.dtb
interesting to know.
Thanks and Regards.
Best Luck.
Jaymin D
Hi juergenvorbach,
Can you please write down your all arguments which shown at 'printenv' command in u-boot
and also mention your details that which type of board you used, about RFS and Kernel uImage,
so its good to answer in best way.
I think there may be problem in u-boot side as I assume.
Jaymin D
Hi Jaymin,
I think it's all written down so far, but I can do it once more
U-Boot > pri
baudrate=115200
boot_fdt=try
bootargs=console=ttymxc0,115200 root=/dev/
bootargs_base=setenv bootargs console=ttymxc0,115200
bootargs_mmc=setenv bootargs ${bootargs} root=/dev/mmcblk0p1 rootwait rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
bootcmd=run bootcmd_mmc
bootcmd_mfg=run mfgtool_args;bootm ${loadaddr} ${initrd_addr} ${fdt_addr};
bootcmd_mmc=run bootargs_base bootargs_mmc;mmc dev 1;mmc read ${loadaddr} 0x800 0x3000;mmc read ${fdt_addr} 0x5000 0x800;bootm ${loadaddr} - ${fdt_addr}
bootdelay=1
bootscript=echo Running bootscript from mmc ...; source
console=ttymxc0
ethact=FEC
ethaddr=00:04:9f:02:6c:b5
ethprime=FEC
fdt_addr=0x18000000
fdt_file=imx6q-sabresd.dtb
fdt_high=0xffffffff
get_cmd=dhcp
initrd_addr=0x12C00000
initrd_high=0xffffffff
ip_dyn=yes
ipaddr=172.30.50.175
loadaddr=0x12000000
loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}
loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}
mfgtool_args=setenv bootargs console=ttymxc0,115200 rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber="" enable_wait_mode=off
mmcargs=setenv bootargs console=${console},${baudrate} ${smp} root=${mmcroot}
mmcboot=echo Booting from mmc ...; run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootm ${loadaddr} - ${fdt_addr};else if test ${boot_fdt} = try; then bootm; else echo WARN: Cannot load the DT;fi; fi; else bootm; fi;
mmcdev=1
mmcpart=1
mmcroot=/dev/mmcblk0p2 rootwait rw
netargs=setenv bootargs console=${console},${baudrate} ${smp} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${uimage}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then bootm ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootm; else echo WARN: Cannot load the DT; fi; fi; else bootm; fi;
netmask=255.255.255.0
panel=Hannstar-XGA
script=boot.scr
serverip=172.30.50.125
uimage=uImage
Environment size: 2364/8188 bytes
U-Boot >
My board is a SABRE Smart Devices Board
MPN: MCIMX6Q-SDB
LOT: X6HJ130373
DTE: 1303
QTY: 1
LPN: RU000098EJ
whatever this all means.
I have downloaded : fsl-L3.10.17_1.0.2_iMX6QDLS_Bundle.tar.gz
and documentation : fsl-yocto-3.10.17_1.0.0.tar.gz
My install script is:
#!/bin/sh
DEV=sdc
#DTB, offset=10M
#did the rest by hand as described in the documentation ... Users guide
sudo fdisk /dev/sdc
sudo mkfs.ext4 /dev/sdc1
sudo mount /dev/sdc1 /home/juergen/tmp/mnt
in u-boot i did:
U-Boot > saveenv
BTW: I ran into kernel CRC Errors the first time, so I corrected 0x2000 to 0x3000 in bootcmd_mmc as shown above, from then on I got a little further but it stopped with the 'Starting kernel ...' message
(0x2000 is still mentioned in the users guide)
refer to my first posting to get all details if anything is missing.
anything more you need to know?
Kind regards
Juergen
Some errors as shown in your argument.
We will correct it, maybe its work.
in setenv bootargs_mmc 'setenv bootargs ${bootargs} root=/dev/mmcblk0p2 rootwait rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666
there are /dev/mmcblk0p2 instead of /dev/mmcblk0p1 (name of SD card partition where uImage) and video=mxcfb1 insted of mxcfb0
set below argument in your u-boot from starting.
setenv console ttymxc1
setenv baudrate 115200
setenv mmcdev 0
setenv mmcpart 1
setenv mmcroot /dev/mmcblk0p1 rootwait rw
setenv mmcargs setenv bootargs console=${console},${baudrate} consoleblank=0 root=${mmcroot} xl4 video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666
check with xl4 and without xl4 in last argument. (don't forget)
after entering all arguments and save it if you get u-boot prompts then you are on correct direction.
and enter " bootm " in u-boot prompts after setting all arguments to extract kernel.
Also provide me some hyper-terminal / minicom output after save all above argument and also your 'printenv' output of u-boot then will get idea and move forward to correct direction.
Hope above information helpful to you.
Best Luck
Jaymin D
Hi Jaymin
bootm reports:
U-Boot > bootm
Wrong Image Format for bootm command
ERROR: can't get kernel image!
U-Boot >
the boot procedure still is:
CPU: Temperature 44 C, calibration data: 0x5a74db7d
Reset cause: POR
I2C: ready
DRAM: 1 GiB
In: serial
Out: serial
Err: serial
Net: FEC
Normal Boot
OK
Starting kernel ...
reporting some OKs after checksum, loading kernel image etc.
U-Boot > printenv
baudrate=115200
boot_fdt=try
bootdelay=1
console=ttymxc1
ethact=FEC
ethprime=FEC
fdt_addr=0x18000000
fdt_high=0xffffffff
get_cmd=dhcp
ip_dyn=yes
loadaddr=0x12000000
mmcargs=setenv bootargs console=ttymxc1,115200 consoleblank=0 root=/dev/mmcblk0p
1 rootwait rw video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666
mmcdev=1
mmcpart=1
mmcroot=/dev/mmcblk0p1 rootwait rw
panel=Hannstar-XGA
script=boot.scr
uimage=uImage
Environment size: 2419/8188 bytes
U-Boot >
I try to write the kernels again, when I have time today or tomorrow.
uImage_imx_v7_mfg_defconfig
Kind regards
Juergen
Hello Juergen,
Thanks for providing logs,
Can you please provide me the all arguments of u-boot? so it's easy to go forward.
printenv
I think so it will work, but after doing some correction.
some more arguments would be set,
setenv script boot.scr
setenv loadbootscript fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
setenv bootcmd mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loaduimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi
setenv uimage boot/uImage
NOTE : important thing here to notice is that for setting uimage arguments give the correct path where your uImage lies on SD card. (i.e. here it is in boot directory - do not include ' / 'before directory)
so revert me back will u-boot environment and also result output after doing above changes.
Suggestion : If you don't want to save all these env in u-boot then just sets it to in u-boot and print to verify all, they set for the current console/season and automatically set default at next time start.(so its easy for testing purpose)
Thanks and Regards
Jaymin D
Hi Jaymin,
I have tried to set these values an received :
U-Boot > setenv script boot.scr
U-Boot > setenv loadbootscript fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${sc
ript};
U-Boot > setenv bootcmd mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then
** Unrecognized filesystem type **
BOOTP broadcast 1
DHCP client bound to address 172.30.50.225
Using FEC device
TFTP from server 172.30.50.125; our IP address is 172.30.50.225
Filename 'uImage'.
Load address: 0x12000000
Loading: T T T
Abort
BOOTP broadcast 1
Using FEC device
Filename 'imx6q-sabresd.dtb'.
Load address: 0x18000000
Loading: T T T T T T
Abort
U-Boot >
It started to boot from net.
I dont have anything running on 172.30.50.225, no tftp server or anything else.
- Why does it try to retrieve from xx.xx.xx.225, my serverip is set to xx.xx.xx.125?
I have done something more after reboot:
U-Boot > setenv uimage boot/uImage
U-Boot >
U-Boot >
U-Boot > bootm
Bad Header Checksum
U-Boot >
So it might be the kernel image???
Kind regards
Juergen
Actually as per your old logs its shown that your loadaddr is loadaddr=0x12000000.
also be sure that your uimage lies at boot/uImage path. Is this correct ??
so also set it to loadaddr=0x80800000, it may be one of reason.
setenv loadaddr 0x80800000
also set some more below arguments.
However its set already or not just set it one more time.
setenv initrd_high 0xffffffff
setenv loaduimage ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}
setenv bootscript echo Running bootscript from mmc ...; source
I am not sure about FTP boot, it because of that it can't get loaduimage or loadbootscript or bootscript or mmcboot that's why it go to run netboot.
also set below argument at last.
mmcboot=echo Booting from mmc ...; run mmcargs; bootm
and please provide me u-boot environments all. (by use of 'printenv') after setting all above arguments.
Best luck
Jaymin D
U-Boot > setenv loadaddr 0x80800000
U-Boot > setenv initrd_high 0xffffffff
U-Boot > setenv loadbootscript fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
U-Boot > setenv loaduimage ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}
U-Boot > setenv bootscript echo Running bootscript from mmc ...; source
## Executing script at 12000000
Wrong image format for "source" command
U-Boot >
U-Boot > setenv mmcboot echo Booting from mmc ...; run mmcargs; bootm
U-Boot >
U-Boot > printenv
it hangs, nothing gets printed.
Another Try:
U-Boot > setenv bootscript echo Running bootscript from mmc ...; source<INTERRUPT>
U-Boot > pri
U-Boot > pri
baudrate=115200
boot_fdt=try
bootdelay=1
console=ttymxc1
ethact=FEC
ethprime=FEC
fdt_addr=0x18000000
fdt_high=0xffffffff
get_cmd=dhcp
ip_dyn=yes
loadaddr=0x80800000
loadbootscript=fatload mmc 1:1 0x80800000
loaduimage=ext2load mmc 1:1 0x80800000
mmcdev=1
mmcpart=1
panel=Hannstar-XGA
script=boot.scr
uimage=uImage
Environment size: 2363/8188 bytes
it stops here
Hi Juergen
you can check below as possible reason
https://bugzilla.yoctoproject.org/show_bug.cgi?id=6703
Hi Igor,
thanks for your response.
The solution provided doesnt change anything in my case.
Disconnecting the hdmi cable or changing some values as described - still the same boot procedure 'till 'Starting kernel ..."
I keep trying, maybe I overread something.
thanx, kind regards
Juergen
Hi Juergen,
are you sure that kernel stops booting or are there no more activity on the console?
May be that's the problem? how to set bootconsole on imx6 board
Stefan
Hi Stefan,
thanx for your response.
that is all I can see at the console when it stops at 'Starting kernel
...', so I think it never really starts to boot.
When I plug in my TFT via HDMI it runs into power save mode or if it
stays connected and I reset it stays in power save mode, just the same
behavior.
But when I boot the android kernel (r13.4) that is provided by freescale
- it runs, but I would like to use the yocto kernel.
kind regards
Juergen
my env is:
U-Boot >
U-Boot > pri
baudrate=115200
boot_fdt=try
bootdelay=1
console=ttymxc0
ethact=FEC
ethprime=FEC
fdt_addr=0x18000000
fdt_high=0xffffffff
get_cmd=dhcp
ip_dyn=yes
loadaddr=0x12000000
mmcdev=1
mmcpart=1
panel=Hannstar-XGA
script=boot.scr
uimage=uImage
U-Boot >
Hi Juergen,
you can try to set ip=none and
also one can try latest FSL Community BSP 1.7 (Dizzy)
~igor
Hi Igor,
thanx.
1st)
where should I set ip=none, in U-Boot?
2nd)
I have downloaded the BSP sources, did a repo sync, but that is all I
know to do.
I've done the following steps, downloaded repo and ...
PATH=$:~/bin
mkdir fsl-community-bsp
cd fsl-community-bsp
-b dizzy
repo sync
I am not that much into all the building process topic, thought I could
download a bunch of binaries and write it to a SD card. It wasn't my
intention to build it by myself - and I guess I don't have the
guidelines how to do all that.
Kind regards
Juergen
Hi Juergen,
yes in uboot (from your original text on this thread):
Hi Igor,
thanx first of all,
I tried:
netargs=setenv bootargs console=${console},${baudrate} ${smp} root=/dev/nfs ip=none nfsroot=${serverip}:${nfsroot},v3,tcp
and
I reduced all down to
netargs=setenv console=ttymxc0,115200
netargs=setenv console=ttymxc1,115200
all with the same behaviour, stops at 'Starting kernel ...'
i always use
$:> run bootcmd
to boot/restart
OK
Starting kernel ...
Kind regards
Juergen
Hi Juergen,
what is about boot with ldo enabled, using
