cst 3.3.1 back_end-hsm Build Problems
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Dear Community,
i am facing with the following problems:
I am trying to build cst-3.1.1 /back_end-hsm source on Windows using gccCompiler. I read the "cst-3.3.1_/code/back_end-hsm/doc/HSM-CST_UG.pdf" tutorial and do all insructions one by one.
->compiling ..\cst-3.3.1\code\cst\code" is not possible, fails
->compiling "..\cst-3.3.1\code\back_end-hsm\src" is not possible, fails. It is not an standalone application and so the output is not an exe file.
->Some base information is missing in HSM-CST_UG.pdf document.
--> Can somebody help us about this topic?
-->How can we build (glue) cst and back_end-hsm together on Windows wth GCC.
My Environment and Installed:
OS: Windows/64, MSys2 64 Bit, GCC
pacman -S mingw-w64-x86_64-gcc make
pacman -S mingw-w64-x86_64-libconfig
pacman -S mingw-w64-x86_64-dlfcn
pacman -S --needed base-devel msys2-devel
pacman -S --needed base-devel mingw-w64-x86_64-toolchain
pacman -S mingw-w64-x86_64-openssl
pacman -S mingw-w64-x86_64-zlib mingw-w64-x86_64-zstd
Kind Regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @AlpinaInformatik ,
The following works for me on Linux, I guess there is a way to mimic this on Windows.
- Extract cst-3.3.1.tgz
- Change into ./cst-3.3.1/code/cst and run: bash -c "OSTYPE=linux64 make rel_bin"
- Change into ./cst-3.3.1/code/back_end-engine/src and run:
- sed -i 's#^ROOT :=.*#ROOT := ../../cst/code#g' ./Makefile
- sed -i 's#^FRONTEND :=.*#FRONTEND := $(ROOT)/obj.linux$(BITNESS)/libfrontend.a#g' ./Makefile
- bash -c "OSTYPE=linux64 make"
The cst binary for the HSM is now ./cst-3.3.1/code/back_end-engine/src/cst
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I think you have to use 3.3.0 (or something like that, some older version) if you would like to compile back_end-hsm without any issues.
Since 3.3.1 you have to use back_end-engine (cst-3.3.1\code\back_end-engine) for HSM backend (which is documented in "AN12812 Using Code-Signing Tool with Hardware Security Module")
If you still would like to compile 3.3.1 with back_end-hsm - you have to fix Makefiles.
Denis
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
"I am trying to build cst-3.1.1 /back_end-hsm source on Windows using gccCompiler."
I saw you performing with cst-3.3.1, Hope you don't mix them while performing.
And, you can try to check gcc compiler, libconfig, and openssl which are installed properly.
such as: gcc -v, pacman -Ss openssl-devel, and pacman -Ss libconfig, respectively.
You might need to check if you have performed under MINGW64 and source code for CST that is not corrupted.
Harvey
