hello
i have an encrypted partition with dm-crypt. on first boot all seems well but after i burn my applications, not always but accusingly, some of my files get corrupted. also after running for some time i also get some of my files corrupted.
before creating a dm-crypt partition, on a normal partition i never got corrupted files.
is there a reason why the encrypted partition is not stable
thanks for the help
Solved! Go to Solution.
i was able to find the problem, i was directed to the solution by Nathan from Timesys. it seems there is a bug in the crypto dirver backlog scenario
Thank you for your interest in NXP Semiconductor products,
Could you share how could I reproduce this issue?
Please confirm if you are following the steps from this guide, this may help out.
Also, what processor are you working with?
hi
i also tested the partition with the test in the manual and got errors. the first test is on a normal partition and second test is on an encrypted partition
dd if=/dev/random of=/tmp/random conv=fsync bs=1M count=32
32+0 records in
32+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 0.335412 s, 100 MB/s
root@imx8mp-var-dart-aion-secure:~# echo 3 > /proc/sys/vm/drop_caches
[ 853.846594] sh (582): drop_caches: 3
---- testing on a normal partition --
root@imx8mp-var-dart-aion-secure:~# time dd if=/tmp/random of=/home/root/testwrite conv=fsync
65536+0 records in
65536+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 0.805649 s, 41.6 MB/s
real 0m0.818s
user 0m0.055s
sys 0m0.643s
root@imx8mp-var-dart-aion-secure:~# rm testwrite
--- testing in the encrypted partition ---
root@imx8mp-var-dart-aion-secure:~# time dd if=/tmp/random of=/data/testwrite conv=fsync
[ 886.872817] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32767 (slots)
[ 886.873141] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[ 886.873144] sdhci-esdhc-imx 30b60000.mmc: swiotlb buffer is full (sz: 8192 bytes), total 32768 (slots), used 32766 (slots)
[ 886.874542] sdhci-esdhc-imx 30b60000.mmc: swiotlb buffer is full (sz: 8192 bytes), total 32768 (slots), used 32766 (slots)
[ 886.874608] ------------[ cut here ]------------
[ 886.874611] WARNING: CPU: 0 PID: 210 at drivers/mmc/host/sdhci.c:1154 sdhci_send_command+0x7e8/0xe6c
[ 886.874625] Modules linked in: iptable_filter ip_tables x_tables crct10dif_ce imx8_media_dev(C) imx_sdma secvio fsl_jr_uio snd_soc_wm8904 imx_rpmsg_tty galcore(O) fuse
[ 886.874656] CPU: 0 PID: 210 Comm: kworker/0:1H Tainted: G WC O 5.15.71+gd567aaeb594f #1
[ 886.874662] Hardware name: DART-MX8M-PLUS Elsec Aion (DT)
[ 886.874666] Workqueue: kblockd blk_mq_run_work_fn
[ 886.874676] pstate: a00000c5 (NzCv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 886.874682] pc : sdhci_send_command+0x7e8/0xe6c
[ 886.874686] lr : sdhci_send_command+0x648/0xe6c
[ 886.874690] sp : ffff80000ae3b960
[ 886.874692] x29: ffff80000ae3b960 x28: 0000000000000000 x27: 0000000000000002
[ 886.874700] x26: 0000000000000000 x25: 0000000000000000 x24: ffff0000c0f38810
[ 886.874708] x23: 000000000000000b x22: ffff0000c53db348 x21: ffff0000c53db3b8
[ 886.874716] x20: ffff0000c53db348 x19: ffff0000c0f38580 x18: ffffffffffffffff
[ 886.874724] x17: 0000000000000000 x16: 00000000302abb46 x15: ffff800009f61fc0
[ 886.874731] x14: ffffffffffffffff x13: ffff800009f61fb1 x12: 7566207369207265
[ 886.874739] x11: ffff800009dd2100 x10: 0000000000000020 x9 : 0000000000007ffe
[ 886.874747] x8 : 0000000000000020 x7 : 000000000000003a x6 : 0000000000007940
[ 886.874754] x5 : ffff0000fb1a5d88 x4 : 0000000000000000 x3 : 0000000000000000
[ 886.874761] x2 : fffffffffffdfbfe x1 : fffffffffffffffe x0 : 00000000ffffffe4
[ 886.874770] Call trace:
[ 886.874772] sdhci_send_command+0x7e8/0xe6c
[ 886.874777] sdhci_send_command_retry+0x40/0x130
[ 886.874782] sdhci_request+0x70/0xc4
[ 886.874786] __mmc_start_request+0x68/0x13c
[ 886.874793] mmc_start_request+0x84/0xb0
[ 886.874799] mmc_blk_mq_issue_rq+0x310/0xa70
[ 886.874805] mmc_mq_queue_rq+0x11c/0x2bc
[ 886.874811] blk_mq_dispatch_rq_list+0x124/0x83c
[ 886.874817] blk_mq_do_dispatch_sched+0x2a4/0x320
[ 886.874822] __blk_mq_sched_dispatch_requests+0x10c/0x15c
[ 886.874827] blk_mq_sched_dispatch_requests+0x38/0x74
[ 886.874832] __blk_mq_run_hw_queue+0x54/0x90
[ 886.874837] blk_mq_run_work_fn+0x20/0x30
[ 886.874843] process_one_work+0x1d0/0x354
[ 886.874848] worker_thread+0x13c/0x470
[ 886.874852] kthread+0x150/0x160
[ 886.874857] ret_from_fork+0x10/0x20
[ 886.874864] ---[ end trace e71339d44b27c803 ]---
[ 886.883023] caam_jr 30902000.jr: unable to map destination
[ 886.891124] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[ 886.891974] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[ 886.891982] caam_jr 30902000.jr: unable to map source
[ 886.892000] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[ 886.892006] caam_jr 30902000.jr: unable to map source
[ 886.892135] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[ 886.892140] caam_jr 30902000.jr: unable to map source
[ 886.892192] EXT4-fs warning (device dm-1): ext4_end_bio:344: I/O error 10 writing to inode 14 starting block 763715)
[ 886.892325] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[ 886.892331] caam_jr 30902000.jr: unable to map source
[ 886.892513] caam_jr 30902000.jr: swiotlb buffer is full (sz: 512 bytes), total 32768 (slots), used 32768 (slots)
[ 886.892518] caam_jr 30902000.jr: unable to map source
[ 886.892701] caam_jr 30902000.jr: unable to map source
[ 886.892828] caam_jr 30902000.jr: unable to map source
[ 886.892864] EXT4-fs warning (device dm-1): ext4_end_bio:344: I/O error 10 writing to inode 14 starting block 764672)
[ 886.892985] caam_jr 30902000.jr: unable to map source
[ 886.893167] caam_jr 30902000.jr: unable to map source
[ 886.893274] caam_jr 30902000.jr: unable to map source
[ 886.893350] caam_jr 30902000.jr: unable to map source
[ 886.893533] caam_jr 30902000.jr: unable to map source
[ 886.893623] caam_jr 30902000.jr: unable to map source
[ 886.893652] EXT4-fs warning (device dm-1): ext4_end_bio:344: I/O error 10 writing to inode 14 starting block 765819)
[ 886.893705] caam_jr 30902000.jr: unable to map source
[ 886.893737] EXT4-fs warning (device dm-1): ext4_end_bio:344: I/O error 10 writing to inode 14 starting block 765863)
[ 886.893873] caam_jr 30902000.jr: unable to map source
[ 886.894001] Buffer I/O error on device dm-1, logical block 765863
[ 886.894025] Buffer I/O error on device dm-1, logical block 765864
[ 886.894030] Buffer I/O error on device dm-1, logical block 765865
[ 886.894035] Buffer I/O error on device dm-1, logical block 765866
[ 886.894039] Buffer I/O error on device dm-1, logical block 765867
[ 886.894044] Buffer I/O error on device dm-1, logical block 765868
[ 886.894048] Buffer I/O error on device dm-1, logical block 765869
[ 886.894052] Buffer I/O error on device dm-1, logical block 765870
[ 886.894057] Buffer I/O error on device dm-1, logical block 765871
[ 886.894061] Buffer I/O error on device dm-1, logical block 765872
[ 886.897488] caam_jr 30902000.jr: unable to map source
[ 886.897683] caam_jr 30902000.jr: unable to map source
[ 886.897868] caam_jr 30902000.jr: unable to map source
[ 886.898052] caam_jr 30902000.jr: unable to map source
[ 886.898236] caam_jr 30902000.jr: unable to map source
[ 886.898335] caam_jr 30902000.jr: unable to map source
[ 886.898359] EXT4-fs warning (device dm-1): ext4_end_bio:344: I/O error 10 writing to inode 14 starting block 755200)
[ 886.898481] caam_jr 30902000.jr: unable to map source
[ 886.898634] caam_jr 30902000.jr: unable to map source
[ 886.898685] EXT4-fs warning (device dm-1): ext4_end_bio:344: I/O error 10 writing to inode 14 starting block 755523)
[ 886.920412] caam_jr 30902000.jr: unable to map destination
[ 887.193383] EXT4-fs warning (device dm-1): ext4_end_bio:344: I/O error 10 writing to inode 14 starting block 763181)
[ 887.455933] EXT4-fs warning (device dm-1): ext4_end_bio:344: I/O error 10 writing to inode 14 starting block 763711)
dd: fsync failed for '/data/testwrite': Input/output error
65536+0 records in
65536+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 1.43458 s, 23.4 MB/s
real 0m1.442s
user 0m0.060s
sys 0m0.661s
Thanks for the inputs,
There shouldn't be reason to be unstable, let me try to replicate the issue.
Joseph
hi
thanks for the quick response. i am creating the partition and mounting it in the initramfs. the creation and mount are the same commands as the manual. The create has --verifyudev parameter. When i run the "dmsetup table --showkey" on the partitions that are encrypted i get a similar result as the manual.
is there any reason why the dm-crypt should be unstable ?
thanks
