can I copy the u-boot.imx image in ram to ROM for next boot up?
搜索替代
662 次查看
damienhuang
Hi all,
I need helps on this.
I downloaded my uboot image (i.e. u-boot.imx) into the ram of my imx6 sabrelite board using the "imx_usb" tool and started runing this image at 0x177ff400. I am wondering if I can transfer this runtime image into SPI ROM for next autoboot without using the "imx_usb" again or runing the 6x_upgrade script.
Will the run time image change from its original contents in file?
thanks in advance.
Cheers,
Damien
标签 (2)
238 次查看
igorpadykov
Hi Damien
yes run time image should work if written to spi with
proper 0x400 offset .
238 次查看
damienhuang
Yes, Igor, you are right.
After restored the header to the runtime image, just write it to 0x400
offset will do.
Cheers,
