can I copy the u-boot.imx image in ram to ROM for next boot up?
次の代わりに検索
664件の閲覧回数
damienhuang
Hi all,
I need helps on this.
I downloaded my uboot image (i.e. u-boot.imx) into the ram of my imx6 sabrelite board using the "imx_usb" tool and started runing this image at 0x177ff400. I am wondering if I can transfer this runtime image into SPI ROM for next autoboot without using the "imx_usb" again or runing the 6x_upgrade script.
Will the run time image change from its original contents in file?
thanks in advance.
Cheers,
Damien
ラベル(2)
2 返答(返信)
240件の閲覧回数
igorpadykov
Hi Damien
yes run time image should work if written to spi with
proper 0x400 offset .
240件の閲覧回数
damienhuang
Yes, Igor, you are right.
After restored the header to the runtime image, just write it to 0x400
offset will do.
Cheers,
