Hello Shravan Sundar Raj,
You would need to extract and install the toolchain manually. You can do so by running:
$ bitbake meta-toolchain-qt5
And then install it with the script that is created with this command. Meta-toolchain is also available if you won’t be using qt5.
I hope this helps!
