boot up by tftpboot
boot up by tftpboot
496 次查看
mm2021
I'm debugging the i.MX 8M Mini board.
Now I can compile the kernel and get Image file. I put the Image file to SD card to replace the old one, the board can boot up to linux smoothly.
Now I'd like to get Image in ubbot by tftpboot.
As far as I know, in uboot, I can use the following command to load Image to ram:
tftp <addr in ram> Image
But how to set the address in ddr?
Thanks!
467 次查看
nxf63675
Hi @mm2021,
Please read the Linux user guide, chapter 4.4.1.2 Downloading an image to MMC/SD, there you will find how to do the configuration and the steps to follow.
https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
For the loadaddr I think it is 0x40480000, also you could see this address if you, on U-boot write printenv and look for that address.
Hope this helps you.
Israel.
487 次查看
mm2021
anybody can give some ideas?
