Hi.
We are porting linux to our board.
We need to boot linux kernel from usdhc2. Because the pins of usdhc1 are used for other purpose.
The u-boot boots form usdhc2. but u-boot can not find the sdcard connecting usdhc2 pins to load kernel image, device tree image.
We also modified device tree of u-boot like following.
We would like to how to change u-boot source code or/and other files.
-----------a part of device tree start ---------------------------------------------
&usdhc1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usdhc1>, <&pinctrl_usdhc1_gpio>;
cd-gpios = <&gpio5 0 GPIO_ACTIVE_HIGH>;
wp-gpios = <&gpio5 1 GPIO_ACTIVE_LOW>;
enable-sdio-wakeup;
keep-power-in-suspend;
status = "disabled"; <-------------------------- change to disabled from okay.
pinctrl_usdhc2_gpio: usdhc2_gpiogrp {
fsl,pins = <
MX7D_PAD_SD2_CD_B__GPIO5_IO9 0x59 /* CD */
MX7D_PAD_SD2_WP__GPIO5_IO10 0x59 /* WP */
pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX7D_PAD_SD2_CMD__SD2_CMD 0x53
MX7D_PAD_SD2_CLK__SD2_CLK 0x13
MX7D_PAD_SD2_DATA0__SD2_DATA0 0x53
MX7D_PAD_SD2_DATA1__SD2_DATA1 0x53
MX7D_PAD_SD2_DATA2__SD2_DATA2 0x53
MX7D_PAD_SD2_DATA3__SD2_DATA3 0x53
&usdhc2 {
pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>;
cd-gpios = <&gpio5 9 GPIO_ACTIVE_HIGH>;
wp-gpios = <&gpio5 10 GPIO_ACTIVE_LOW>;
enable-sdio-wakeup;
status = "okay";
-----------a part of device tree end ---------------------------------------------
-----------console output start--------------------------------------------
U-Boot 2017.03 (Apr 01 2020 - 13:16:22 +0900)
DRAM: 1 GiB
MMC: FSL_SDHC: 0
MMC Device 1 not found
*** Warning - No MMC card found, using default environment
Display: TFT43AB (480x272)
Video: 480x272x24
no mmc device at slot 1
Net: No ethernet found.
Normal Boot
Autoboot in 3 seconds
-----------console output end ---------------------------------------------
Hi Hideo
usdhc2 example can be found in imx7d-12x12-lpddr3-arm2.dts :
imx7d-12x12-lpddr3-arm2.dts\dts\boot\arm\arch - linux-imx - i.MX Linux kernel
Also please pay attention to "root" parameter in Table 10. Common kernel boot parameters
attached Release Notes and sect.4.7.1 Running Linux OS from MMC/SD Linux Guide.
Dear igor.
Thank you for replying to my question.
I solved by myself.
1.disable iomuxc_lpsr , usdhc1 , usdhc3 in device tree;
2.enable usdhc2 in device tree like the following;
reg_sd2_vmmc: regulator@7 {\
compatible = "regulator-fixed";
regulator-name = "VDD_SD2";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
gpio = <&gpio5 11 GPIO_ACTIVE_HIGH>;
startup-delay-us = <200000>;
off-on-delay = <20000>;
enable-active-high;
&usdhc2 {
pinctrl-0 = <&pinctrl_usdhc2>;
cd-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>;
wp-gpios = <&gpio5 10 GPIO_ACTIVE_HIGH>;
wakeup-source;
vmmc-supply = <®_sd2_vmmc>;
enable-sdio-wakeup;
status = "okay";
3.modify board_mmc_get_env_dev() in mx7sabresd.c
int board_mmc_get_env_dev(int devno)
devno--;
return devno;
Best regards.
Hideo Yamashiro.
