blhost compilation for Arm-Linux
781件の閲覧回数
anshulkhare
Hi All,
i am using blhost 2.6.7 for communicating with flash loader.
i am able to compile it on linux system. as per the release notes, it is possible to compile it for Arm-linux.
can anyone guide me here, how to compile it for Arm-Linux.
Anshul
763件の閲覧回数
Andrew9090
  • the paths you must use to the appropriate system header files and libraries (for smiONE Card example, glibc and libstdc++)
  • the appropriate standard options and object files (such as those containing the application entry point function and C library initialization code).
Configuration of the ARM Compiler toolchain can be performed:
  • automatically with armcc
  • manually by specifying particular paths that are used for finding header files and libraries.
3 返答(返信)
764件の閲覧回数
Andrew9090
764件の閲覧回数
anshulkhare
Hi @Bio_TICFSL
able to build blhost, for arm-linux.
facing issues in sdphost build for arm-linux.
Thanks & Regards,
Anshul Khare
767件の閲覧回数
Bio_TICFSL
Yes, it is possible you have to read the user guide and download the proper toolchain.
