Yolov5 Tflite CPU vs VX_delegate NPU
Search instead for
taklause
Hello, we have trained successfully a YoloV5 and converted it to uint8.
The benchmark
./benchmark_model --graph=model.tflite --external_delegate_path=/usr/lib/libvx_delegate.so --enable_op_profiling=true
benchmark output :
External delegate path: [/usr/lib/libvx_delegate.so]
Loaded model model.tflite
Vx delegate: allowed_builtin_code set to 0.
Vx delegate: error_during_init set to 0.
Vx delegate: error_during_prepare set to 0.
Vx delegate: error_during_invoke set to 0.
EXTERNAL delegate created.
Going to apply 1 delegates one after another.
Explicitly applied EXTERNAL delegate, and the model graph will be completely executed by the delegate.
The input model file size (MB): 1.98869
Shows inference speed of ~66 ms which is not too bad. The output also shows that the inference is completely executed on the npu.
I started to implement the extraction of the bounding box from the prediction of the input image. I used python for a quick evaluation :
delegate = [tflite.load_delegate(library="/usr/lib/libvx_delegate.so", options={"logging-severity":"info"})]    interpreter = tflite.Interpreter(model_path=weights,experimental_delegates=delegate)
interpreter.allocate_tensors()
The following image is twice inferenced, once with the experimental_delegates and once without.
The "good" result was from the CPU. The NPU delivers random bounding boxes. The code behind the extraction is exactly the same.
How can that be?
Inference with NPUInference with NPU
Inference on CPUInference on CPU
abhishek_ml
@taklause can you share the inference code ? I am facing similar issue.
taklause
Hi @Qmiller ,
I did as the document suggested.
  1. I exported the .pb file from the finetuned ultralytics model with 256x256x3 input format.
  2. With the .pb model, I converted it with the settings in the following image:
  3. Converter SettingsConverter Settings
  4. Then I uploaded the converted .tflite model to the NPU and did the same test as before. With similar results..
    1. The one with the correct prediction is executed with the CPU, and the model is converted from Ultralytics directly.
    2. The one with the correct prediction is the EIQ Converted model, executed on the CPU
    3. The one with the no prediction is the EIQ Converted model, executed on the NPU
As a remark, all the models are quantized with the same images. The models (raw - pb and converted tflite from Ultralytics) are also attached.
NPU EIQ CONVERTEDNPU EIQ CONVERTED
CPU EIQ CONVERTEDCPU EIQ CONVERTED
CPU ULTRALYTICS DIRECTCPU ULTRALYTICS DIRECT
Qmiller
Hi @taklause
Send you the test code.
taklause
Hello @Qmiller ,
I reply directly in hope someone would help me fix the problem ;).
I m still having no detection inferencing with the NPU. Only the CPU gives me good detections, even when
I convert them with the eIQ tool you suggested.
Thanks, regards Daniel
Qmiller
Hello @taklause
Please provide test image and label.
taklause
Hello @Qmiller,
thanks for the support.
I attach two models, the pb file as the yolov5 unconverted and the efficientdetlite0 already converted.
Both deliver no results with the NPU, only with the CPU.
It is only a person detector, trained with the persons from COCO17 and a little bit of our data. There are three images and the label.txt.
Thanks again for looking into it.
Qmiller
Which tag you used about yolov5, v7.0?
Have you changed any net struct in your training?
taklause
No, we did not change the structure apart from the input dimension. It is the version 5.0
taklause
Hi @Qmiller ,
the access to the file was denied, I cant watch it.
