Yocto bsp setup
Yocto bsp setup
1,134 次查看
jiangdongli
I get a error:  "fatal: bad config file line 1 in .git/config"  when i run command: "repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga" in fsl-arm-yocto-bsp directory. But i can't find the file .git/config in current directory.
Did anyone encounter a similar problem? i need help.
thanks!
标签 (3)
标记 (1)
1,033 次查看
jiangdongli
I have solved this problem myself, it caused by our EIS
1,034 次查看
jiangdongli
1,033 次查看
gusarambula
Hello Jiangdong Li,
I'm glad you solved the problem. Thank you for letting us know!
