Yocto bsp setup
Yocto bsp setup
521 次查看
jiangdongli
I get a error:  "fatal: bad config file line 1 in .git/config"  when i run command: "repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga" in fsl-arm-yocto-bsp directory. But i can't find the file .git/config in current directory.
Did anyone encounter a similar problem? i need help.
thanks!
标签 (3)
标记 (1)
420 次查看
jiangdongli
I have solved this problem myself, it caused by our EIS
421 次查看
jiangdongli
420 次查看
gusarambula
Hello Jiangdong Li,
I'm glad you solved the problem. Thank you for letting us know!
