Yocto ADT Eclipse Plugin C++11 (Autotools) configuration
1,334件の閲覧回数
arnaudne
Hi everyone,
Context:
I am using an iMX6UL EVK with a custom, working, image generated with Yocto.
I would like to use Eclipse to develop C++ applications for this target, I then used :
bitbake my-image -c populate_sdk
bitbake meta-ide-support
This gave me an SDK and toolchain that I installed by executing the generated script.
I configured the Eclipse IDE (Mars.2) to use Yocto ADT Plugin, and configured it to use my SDK and  toolchain.
I created a new C++ application (Yocto Autotools Hello World Project), built and deployed the template without any error (It successfully ran on the target board).
Problem :
But the problem is that when I create a "more" complex application and have to use C++11, I can't compile anymore (The compiler is complaining about C++11 compatibility).
#error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
I got rid of this error by adding in Project Properties -> Autotools -> Configure -> Advanced :
CXXFLAGS="${CXXFLAGS} -std=gnu++11" CPPFLAGS="${CPPFLAGS} -std=gnu++11"
But then came other (ugly) errors:
undefined reference to `Audio::Audio(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
undefined reference to `Audio::~Audio()'
For reference this is my Audio class:
Audio.h
#include <iostream>
#include <string>
#include <cstdint>
#include <alsa/asoundlib.h>
#define SAMPLE_SIZE (sizeof(int))     // bytes per sample
typedef struct {
    int numSamples;
    short *pData;
} wavedata_t;
class Audio {
public:
    Audio(std::string pcm_device = "default");
    virtual ~Audio();
    bool playbackFile(std::string path);
protected:
    snd_pcm_t *pcm_handle;
    bool configurePCM(std::string pcm_device, uint channels = 2, uint sampleRate = 44100, snd_pcm_format_t format = SND_PCM_FORMAT_S16_LE, snd_pcm_access_t access = SND_PCM_ACCESS_RW_INTERLEAVED);
    bool closePCM();
    // Helpers
    bool loadWavFile(std::string path, wavedata_t *pWaveStruct);
Audio.cpp
#include "Audio.h"
Audio::Audio(std::string pcm_device) {
    configurePCM(pcm_device);
Audio::~Audio() {
    closePCM();
bool Audio::playbackFile(std::string path) {
    <code>
bool Audio::configurePCM(std::string pcm_device, uint channels, uint sampleRate, snd_pcm_format_t format, snd_pcm_access_t access) {
    <code>
bool Audio::closePCM() {
    <code>
// Read in the file to dynamically allocated memory.
// !! Client code must free memory in wavedata_t !!
bool Audio::loadWavFile(std::string path, wavedata_t *pWaveStruct)
     <code>
Question :
How should I configure Eclipse to successfully compile C++11 applications using Autotools via Yocto ADT Plugin ?
Thanks in advance. :smileyhappy:
Arnaud (France)
ラベル(2)
2 返答(返信)
607件の閲覧回数
Yuri
  According to https://www.kernel.org/doc/
C99 standard (current version of the C programming language) is supported.
So, it is good idea to use it with Linux apps.
Yuri
607件の閲覧回数
arnaudne
Thank you for your reply,
But what if I must use C++11 ? What should I do to make it work ?
Thank you
Arnaud
