I recently upgraded from jethro branch to morty branch. After that, X11 forwarding is not working?
Notes:
Kernel: 4.1.x
Image: core-image-multimedia-full
Configuration: X11Forwarding is enabled in /etc/ssh/sshd_config file in the board.
Hello OtavioSalvador , would you know if there is a known issue regarding this on the Morty branch?
Hello gusarambula, I did fix this in past for a customer. If I recall correctly, the cause of the change was a more strict default setting from OpenSSH and I ended adjusting it for the customer's needs.
I found xauth is missing in the image . When I added that to image, it's working now!
