Windows 10 IoT Enterprise with GPIO Controller
hankwang
Hello, I have a GPIO as an output pin that I need to control. I want to know how to control it. Do you have any demo utilities or sample code?
My CPU is 8M Plus.  This pin needs to be controlled. you can refer the attached file.
hankwang
Hello, is there any update?
Alejandro_Salas
Hello @hankwang
I sent you a direct message. I will re-send to you.
Best regards.
Salas.
hankwang
Hi @Alejandro_Salas  Got it... This tool can switch GPIO levels to high or low. The GPIO tool is good.
