Hi, I have an 8MP processor and the UART1 and UART 2 pin designs are the same as the EVK board.
The only difference is that my motherboard doesn't have CTS/RTS.
I tested UART1 loopback and couldn't get the data.
I use UART2 to communicate with the laptop, UART2 can communicate with the laptop.
The difference between UART1 and UART2 is RTS/CTS.
About RTS/CTS of UART1. Where can I disable it for UART1?
Solved! Go to Solution.
Hi @michal_hromadka Sorry, no problem with UART. The problem is that my motherboard is broken.I changed the board and UART communication is good.
Hello @hankwang,
Could you please describe how you tested the loopback with UART1?
By default the UART1 is not enabled in Win IoT BSP. Did you enable it in the BSP source codes?
Michal
