Window10 IoT Enterprise BSP1.5.0 USB3.0 issue
okuda
HI,
When we insert a USB 3.0 compatible USB memory into the USB2 (Type A) of the NXP reference board, the USB memory is not recognized.
The OS being used is Windows 10 IoT Enterprise BSP 1.5.0, as stated in the subject.
The manufacturer and model number of the USB memory used are as follows:
manufacturer : Transcend
model number : TS16GJF700
Please advise how to solve this issue.
Best regards.
Koji Okuda
JorgeCas
- Do you get error logs?
- All USB devices except USB Pen Drive working fine?
- Have you tried other USB Pen Drive models/manufacturers? Is there the same problem?
You can also try Usbview program, to see detailed information about USB devices.
Best regards.
okuda
Dear JorgeCas,
Thank you for your reply.
 How can I get the error log?
 (Obtaining via remote connection of windbg, etc.)
 Unfortunately, we do not have any USB 3.0 compatible USB devices other than
 USB memory sticks.
 The following USB memory sticks were not recognized:
 manufacturer : ELECOM
    model : MF-HSU3A16GBK
Would it be possible for your company to carry out a similar check using a reference board?(We think you'll be able to see this phenomenon straight away.)
If the USB 3.0 compatible USB memory is recognized correctly, please tell us the manufacturer and model number of the USB memory.
Best regards.
Koji Okuda
JorgeCas
The error could be checked in a yellow bang in the device manager.
This issue was recreated in our reference design and was solved by the next:
- Open iMX8BoardInit.c file (\mu_platform_nxp\NXP\MX8M_PLUS_EVK\Library\iMX8BoardLib\)
- Find and comment out or delete this row:
/* Disable PHY suspend (ERR011231) */
out32(base + DWC3_GUSB2PHYCFG, (reg | DWC3_GUSB2PHYCFG_SUSPHY_MASK));
- Rebuild the FW
Best regards.
okuda
Dear JorgeCas,
We are now able to recognize the USB 3.0 compatible USB memory stick, but I would appreciate it if you could answer the following additional questions.
1. We checked the errata for iMX8mp, but ERR011231 was not present.
  This was described in the errata for IMX8MDQLQ_2N14W.
  Based on the above, does this mean that the processing you mentioned was not originally necessary for the iMX8mp?
2.Will commenting out the process you mentioned affect other operations?
 For example, waking up from power saving mode using a USB device
Best regards.
Koji Okuda
JorgeCas
1. Yes, it was reported and solved in i.MX8MP by internal team.
2. That issue has not been reported.
Best regards.
okuda
Dear JorgeCas,
We will continue to carry out our evaluations.
This matter will now be considered closed.
Thank you very much for your support until the end.
Best regards.
Koji Okuda
okuda
Dear JorgeCas,
We performed the steps as instructed, and was able to recognize the USB memory stick that was compatible with USB 2.0 and USB 3.0.
The issue has been resolved, but we would like to confirm the following:
Best regards.
Koji Okuda
