- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hi community,
I am trying to run a demo of RPMsg with 8MMINILPD4-EVK.
linux is 4.14-sumo and RTOS is FreeRTOS with rpmsg_lite.
The following thread is helpful, but it does not work well.
iMX8QXP: Use RPMSG to wake up M4 and A35
Are there any documents that might be helpful?
And where is the source code of "imx8mm_m4_TCM_rpmsg_lite_pingpong_rtos_linux_remote.bin"?
As far as I checked, it was looping endlessly with rpmsg_ns_announce-> rpmsg_lite_format_message-> vq_tx_remote-> RL_ASSERT.
The value of buffer_len seems to be strange as follows.
[virtqueue_create_static (151)] vq->vq_nentries = 2, vq->vq_ring_size = 4126, vq->vq_ring_mem = 0x90010000
[vring_init (151)] vr->desc = 0x90010000, vr->avail = 0x90010020, vr->used = 0x90011000
[virtqueue_create_static (151)] vq->vq_nentries = 2, vq->vq_ring_size = 4126, vq->vq_ring_mem = 0x90018000
[vring_init (151)] vr->desc = 0x90018000, vr->avail = 0x90018020, vr->used = 0x90019000
[RPMsgTask (100)] rpmsg_lite_remote_init OK (0 msec)
[RPMsgTask (102)] Wating rpmsg_lite_is_link_up (0 msec)
Link is up!
[RPMsgTask (111)] rpmsg_queue_create OK (1990 msec)
[RPMsgTask (118)] rpmsg_lite_create_ept OK (1990 msec)
[virtqueue_get_available_buffer (355)] head_idx = 0, *avail_idx = 18407, *len = 3878398162
buffer = 3D9A5489, buff_len = 3878398162, idx = 18407
[virtqueue_add_consumed_buffer (373)] head_idx = 18407, vq->vq_nentries = 2,
T.kashiwagi
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi all,
I solved this, and I will post the settings.
About document , please refer to below.
- "2.8.5 Running i.MX RPMsg Test Programs" in imx-yocto-L4.14.78_1.0.0_ga/i.MX_Reference_Manual.pdf
About RTOS sample code , please refer to below.
- boards\evkmimx8mm\multicore_examples\rpmsg_lite_str_echo_rtos (Please Create SDK_2.5.0_EVK-MIMX8MM via SDK dashboard. )
How to run RPMsg sample is as follows.
- precondition
- In menu configuration enable the following module:
- Device Drivers > IMX RPMSG pingpong driver -- loadable modules only
- Device Drivers > IMX RPMSG tty driver -- loadable modules only
- Load Kernel module "imx_rpmsg_tty.ko"
- $ insmod imx_rpmsg_tty.ko
- CM4 binary is "imx8mm_m4_TCM_rpmsg_lite_str_echo_rtos.bin"
Please note that CM4 and kernel modules do not work if they are mismatched.
The procedure is as follows.
1. Please boot linux and "imx8mm_m4_TCM_rpmsg_lite_str_echo_rtos.bin". dmesg will be as follows.
root@imx8mmevk:~# dmesg | grep rpmsg
[ 0.861067] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.861114] virtio_rpmsg_bus virtio0: creating channel rpmsg-virtual-tty-channel-1 addr 0x1e
[ 0.873812] imx rpmsg driver is registered.
root@imx8mmevk:~#
2. Please load "imx_rpmsg_tty.ko" ($ insmod imx_rpmsg_tty.ko). RPMsg tty driver is installed (/dev/ttyRPMSG30 appers).
[ 651.497802] imx_rpmsg_tty virtio0.rpmsg-virtual-tty-channel-1.-1.30: new channel: 0x400 -> 0x1e!
[ 651.506808] Install rpmsg tty driver!
[ 651.512199] rpmsg_tty_cb68 65 6c 6c 6f 20 77 6f 72 6c 64 21 hello world!
root@imx8mmevk:~#
The following message is displayed on the CM4 console at this point.
Nameservice sent, ready for incoming messages...
Get Message From Master Side : "hello world!" [len : 12]
3. you can echo string as follows.
T.Kashiwagi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi all,
- precondition
root@imx8mmevk:~#
root@imx8mmevk:~#
T.Kashiwagi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
For i.MX8M Mini RPMsg-related documentation, you could refer to the RPMsg information included on the “i.MX Linux Reference Manual” document, included on the “L4.9.123_2.3.0_8MM_GA_LINUX_DOC” package.
Hope this will be useful for you.
Best regards!
/Carlos
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Carlos
Thank you for responding.
My current situation is as follows.
・ In RTOS, I was able to load and execute the sample source (rpmsg_lite_pingpong_rtos_linux_remote). However, it will not be executed from "Send Name Service Announcement".
・ In Linux, I can not execute unit_test. There is no "/ dev / ttyRPMsg".
I have read “i.MX Linux Reference Manual” document. I checked kernel config and exectuted "insmod" as follows.
• Device Drivers > IMX RPMSG pingpong driver -- loadable modules only
• Device Drivers > IMX RPMSG tty driver -- loadable modules only
root@imx8mmevk:/lib/modules/4.14.78-imx_4.14.78_1.0.0_ga+g94da7bdc489b/kernel/drivers/rpmsg# insmod im
x_rpmsg_tty.ko
insmod: ERROR: could not insert module imx_rpmsg_tty.ko: File exists
"imx_rpmsg_tty.ko" appears to be loaded but there is no "/ dev / ttyRPMsg".
Do you know what caused it?
T.Kashiwagi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi all
I changed "RPMSG_LITE_SHMEM_BASE" as follows.
#define RPMSG_LITE_SHMEM_BASE 0xb8000000
and "rpmsg_ns_announce" was executed.
[RPMsgTask (88)] Start (0 msec)
[virtqueue_create_static (151)] vq->vq_nentries = 2, vq->vq_ring_size = 4126, vq->vq_ring_mem = 0xB8000000
[vring_init (151)] vr->desc = 0xB8000000, vr->avail = 0xB8000020, vr->used = 0xB8001000
[virtqueue_create_static (151)] vq->vq_nentries = 2, vq->vq_ring_size = 4126, vq->vq_ring_mem = 0xB8008000
[vring_init (151)] vr->desc = 0xB8008000, vr->avail = 0xB8008020, vr->used = 0xB8009000
[RPMsgTask (101)] rpmsg_lite_remote_init OK (0 msec)
[RPMsgTask (103)] Wating rpmsg_lite_is_link_up (0 msec)
Link is up!
[RPMsgTask (112)] rpmsg_queue_create OK (1980 msec)
[RPMsgTask (119)] rpmsg_lite_create_ept OK (1980 msec)
[virtqueue_get_available_buffer (355)] head_idx = 0, *avail_idx = 0, *len = 512
buffer = 78040000, buff_len = 512, idx = 0
Nameservice announce sent.
Next, I tried to execute "/unit_tests/Remote_Processor_Messaging/mxc_mcc_tty_test.out" according to i.MX_Reference_Manual.
I enabled the following module:
but "/dev/ttyRPMSG30" could not be found. Which tty can I use instead?
T.Kashiwagi
