Referring to the rpmsg_lite_pingpong_rtos_linux_remote multicore example, what is the purpose of the rpmsg_ns_bind()/unbind() calls? The handle returned by the bind is not used, and I found I can comment those two lines out with no negative effect.
Ed
Hi @EdSutter
You can go through the middleware/multicore/rpmsg_lite/lib/rpmsg_lite/rpmsg_ns.c
Harvey
