What does "Hello World" do, and how to see the code behind it?
2,317 次查看
MikeJin
Thanks for reply from Renato. This is Mike Jin from PSU again.
What does "Hello World" do if I can make everything work correctly?
I see the option to generate package, but how can I identify the C code corresponding to the helloworld pack?
How can I implement a pack and load into ltib SDK?
Is there any freescale solution for graphic? like QT, or lab view?
How can I setup cross compiler for gcc&g++ for imx53?
Mike Jin
PSU EcoCAR2/EcoCAR
标记 (2)
2,195 次查看
Frias
Hello Mike,
I just posted the Winter workshop pdf on the Wall of the group.
Mike P will also post additional instructions on how to build the environment.
Renato
Mike Jin said:
Hi Renato,
I talked to our team co-leaders for clearance and information. I learned nobody attended winter workshop Freescale development training because of illness of a team member. We are sorry that we need repeated information from Freescale.
In the meantime, I am not expecting LTIB to work. Can you give me instruction on how to setup gcc/g++ cross-complier for imx53QSB?
Also, is it possible for us to get the new VM as you mentioned in the post before? Either FTP/HTTP file transfer or email is fine. My Penn State email mxj5057@psu.edu should be able to handle up to 16GiB per file per email.
Mike Jin
Penn State EcoCAR2
Penn State Computer Science 2012 BS candidate
2,195 次查看
MikeJin
Hi Renato,
Mike Jin
Penn State EcoCAR2
2,195 次查看
Frias
Hello Mike,
These were covered on the Winter workshop, I'll post the presentations here shortly.
Please talk with someone from PSU that attended the class, so you can get access to the new VM as well.
Renato
