Watchdog reboot on overloading IPU with Linux 4.1.15 in iMX6Q
993件の閲覧回数
ivyliu
We are using Linux 4.1.15 in iMX6Q (iMX6Q). The display resolution is 1920x120
When we overloading IPU by keep queuing a buffer to IPU for displaying in a gapless loop, and with watchdog enabled, the monitor will reset randomly, in 30min - 11 hours. This issue happened in room temperature.
When the watchdog is disabled, there is no issue with the same test.
The issue happened very randomly, we have thought about the CPU temperature, but when we increased the CPU temperature to 60C - 80C, the issue did not happen.
Have someone had the similar issue?
Could someone help us with this issue?
Thanks and Best Regards,
Ivy
ラベル(3)
7 返答(返信)
933件の閲覧回数
ivyliu
@joanxie  Hi Joanxie,
 Do you have any thoughts on this issue?
Thanks and Best regards,
Ivy
986件の閲覧回数
joanxie
did you test your own customized board, right? all of boards have this issue or only some of them?
976件の閲覧回数
ivyliu
Hi Joanxie,
Yes, it is on our customized board. The issue happens on >95% boards.
Ivy
975件の閲覧回数
ivyliu
Hi Joanxie,
Yes, it is on our customized board. It happened on >95% boards.
Ivy
876件の閲覧回数
joanxie
I have already  mailed to you, pls check
866件の閲覧回数
ivyliu
Hi Joan,
Not sure why I did not get your email.
Could you please help to send it again?
Ivy
841件の閲覧回数
joanxie
did you get support from any distributor? I got the same questions from them, if yes, pls contact them
