Wake up using MPR121 interrupt
Search instead for
winstonrodrigue
Dear Pals,
       I am working on IMX53_smd board (SABRE tablet) ...
So I wanted to make this board to wake up when I touch the touch keys (MPR121) .
     I can wake up the system using GPIOs as well as volume + / volume - keys...
static struct gpio_keys_button smd_buttons[] = {
       GPIO_BUTTON(MX53_PAD_EIM_A24__GPIO5_4, TOUCH_INTERRPT ,1,"touching",1),
        GPIO_BUTTON(MX53_SMD_KEY_VOL_UP, KEY_VOLUMEUP, 1, "volume-up", 1),
        GPIO_BUTTON(MX53_SMD_KEY_VOL_DOWN, KEY_VOLUMEDOWN, 1, "volume-down", 1),
in above code I wanted to know where is KEY_VOLUMEUP and KEY_VOLUMEDOWN is defined.. because when i compile
i get error saying TOUCH_INTERRPT not defined...
  One more thing......
  If the system is sleep /suspend mode whether the MP121 chip gets the power ???
   Winston,
Labels (2)
admin
Specialist II
AdrianAlonso replied:
KEY_VOULUMEUP, KEY_VOULUMEDOWN are macros defined in "include/linux/input.h"
the GPIO_BUTTON macros help to map a given GPIO to a Key code that user space applications will interpret such a key volume up;
You can define an macro for TOUCH_INTERRUPT, but typically for touch screen drivers the interrupt line is used to trigger a new read on MPR121 and emit the X,Y input events.
In MPR121 touch screen driver handles suspend/resume callbacks to properly power down/up the device.
See drivers/input/keyboard/mpr121.c
And from arch/arm/mach-mx5/mx53_smd.c code:
static struct i2c_board_info mxc_i2c1_board_info[] __initdata = {
     .type = "sgtl5000-i2c",
     .addr = 0x0a,
    .type = "mpr121_touchkey",
    .addr = 0x5a,
    .irq = gpio_to_irq(MX53_SMD_KEY_INT),
    .platform_data = &mpr121_keyboard_platdata,
    .type = "mag3110",
    .addr = 0x0e,
    .irq = gpio_to_irq(MX53_SMD_eCOMPASS_INT),
The letters in bold show where mpr121 driver is associated and MX53_SMD_KEY_INT correspond to GPIO 5_4
winstonrodrigue
thank you..... :smileyhappy:
