Wake Up A9 core from the Sleep in imx6sx
nilesh_patel
We are using imx6sx custom board and we need sleep and wakeup functionality based on  GPIO interrupt.
Our requirement:
1) put linux into sleep mode using echo mem > /sys/power/state command,
2) Wakeup A9 core linux when GPIO interrupt occurs.
we have use GPIO7_IO8.
for that I have created node in imx6sx-sdb.dtsi file as below:
gpio-keys {
    compatible = "gpio-keys";
     power {
             label = "wake-up";
             gpios = <&gpio7 8 1>;
             linux,code = <116>;
             gpio-key,wakeup;
using above changes in .dtsi file i get below node:
/sys/devices/soc0/gpio-keys/power/wakeup
then, I use below command to enable it
echo enabled > /sys/devices/soc0/gpio-keys/power/wakeup
using below command I put linux into sleep mode
then, we give interrupt on GPIO7_IO8, using button switch but I am not able wake-up linux.
So, Please provide your expert advice to fix this issue.
Nilesh Patel
Labels (3)
vinothkumars
Senior Contributor IV
Hi Nilesh Patel,
Will you please give your configuration. I am also struggling in wake up.
Thanks & Regards,
VinothS,
Vinothkumar Sekar
Hi Nilesh
for configuring gpio interrupt one can look at
Configure GPIO as interrupt source
How to enable GPIO1 on X27 to act as an interrupt handler for max14830? - Toradex Community
