Voltage supply to i.MX6SL when DDR3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hi all
I'm using i.MX6SL and PF0100 and have question about voltage supply when I use DDR3.
Can MMPF0100F4AEP supply both NVCC_1P2V and NVCC_DRAM ?
According to the EVK's schematic, NVCC_1P2V and NVCC_DRAM are supplied from different LDO.
NVCC_1P2V is VGEN1 and NVCC_DRAM is SW3A/B.
However, MMPF0100F4AEP has only one 1.5V output.
So I plan to supply both NVCC_1P2V and NVCC_DRAM from SW3A/B.
Do I need to supply voltage separately ?
Ko-hey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Ko-hey
recommended to power it from separate clean LDO as it is used by
oscillator circuit as described in datasheet
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Igor
Thank you for your reply.
So NXP recommend to add external LDO for supplying 1.5V to NVCC_1P2V.
Is it correct ?
Ko-hey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Ko-hey
yes correct.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Igor
I understand that NXP recommend to supply voltage to NVCC_1P2V separately.
Let me confirm about supplying NVCC_1P2V again.
Does NVCC_1P2V have to supply voltage before POR_B is asserted ?
MMPF0100F4AEP has LDO that isn't programed such as VGEN2.
If I can supply voltage to NVCC_1P2V after POR_B is asserted, I want to use those LDOs.
I would rather not add a external LDO as much as possible.
So please advise me.
Ko-hey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Igor
I found following Community.
https://community.freescale.com/message/405181#comment-405181
As far as I checked the community, it have to be supplied voltage to NVCC_1P2V separately.
Thank you for your corporation.
Ko-hey
