Voltage difference between VDD_ARM_CAP and VDD_SOC_IN
833件の閲覧回数
kladu
we are using i.MX6ULL with fixed power supplies (not PMIC). Datasheet (Table 10, Page 24) claims that VDD_SOC_IN MUST be 125 mV higher than the LDO Outputs.
Difference between VDD_SOC_IN and VDD_ARM/SOC_CAP at upper voltage limit (1.5V vs 1.26V) is larger than 125mV.
Should this difference be understood as exactly 125mV or at least 125mV? If it is exactly, what is the tolerance and how to deal with upper voltage level mismatch?
kladu
826件の閲覧回数
igorpadykov
Hi Borut
yes it should be at least 125mV, sorry for confusion.
2 返答(返信)
822件の閲覧回数
kladu
That's what I thought, thanks Igor.
827件の閲覧回数
igorpadykov
Hi Borut
