Using ZMK for blobs
Using ZMK for blobs
1,410 次查看
eren_yilmaz
Thanks Yuri.
As a workaround for SEC_CONFIG being not set, can I use ZMK since that can be set in a non-secure mode, and have CAAM use that for blob encapsulation and decapsulation?
1,299 次查看
Yuri
Correct,  ZMK cannot be used in non-secure mode with CAAM.
~Yuri.
5 回复数
1,299 次查看
Yuri
  from i.MX6 Security RM:
When the chip is in the non-secure state, CAAM cannot decapsulate blobs that were
encapsulated while CAAM was in a trustworthy state (either secure state or trusted state).
Yuri
1,299 次查看
eren_yilmaz
Hello  Yuri,
Yes I know that. But my question is for operations in non-secure state.
Can CAAM use ZMK to encapsulate and decapsulate blobs in a non-secure state?
1,299 次查看
Yuri
  In non-secure mode a fixed default key with a known value  is used in place of the master key.
Yuri.
1,299 次查看
eren_yilmaz
Hi Yuri,
So ZMK cannot be used in non-secure mode with CAAM? Instead of that default known key.
1,300 次查看
Yuri
~Yuri.
