Using WiFi on i.MX8M EVK
搜索替代
2,790 次查看
philippemidol-m
I would like to use the integrated wifi device of the i.MX8MQ EVK under linux. Afterthe boot I can see the the PCI device:
root@imx8mqevk:~# lspci -s 01:00.0 -v
01:00.0 Network controller: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter (rev 32)
Flags: bus master, fast devsel, latency 0, IRQ 265
Memory at 18000000 (64-bit, non-prefetchable) [size=2M]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit-
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] Virtual Channel
Capabilities: [168] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [178] Latency Tolerance Reporting
Capabilities: [180] L1 PM Substates
Kernel driver in use: hif_pci
Kernel modules: wlan
But there is no corresponding interface and iw can't detect any wifi device.
What can be wrong with my system?
Philippe
1,895 次查看
Hi Philippe
one can try procedure described in sect.4.12 Wi-Fi QCA6174
attached Linux Manual and Demo Images on link
i.MX Software|NXP
1,896 次查看
Hi Philippe
i.MX Software|NXP
1,895 次查看
philippemidol-m
I missed this doc!!
It works now.
Thanks.
Philippe
