I used the current MX8 DDR tool to generate DDR training code for U-Boot (ddr_init.c and ddrphy_train.c). The code runs successfully on my custom i.MX8 board with U-Boot from the imx_v2017.03_4.9.51_imx8m_beta branch.
I now updated U-Boot to the NXP imx_v2017.03_4.9.51_imx8m_ga release. But now U-Boot does not work anymore. SPL reports successful training, but hangs when jumping into the main U-Boot code. See the output below.
I updated ATF and imx-mkimage to the GA version. I am using the firmware files from the imx-firmware version 7.4 package.
Should I use an newer version of the DDR tool? If so, where can I get it?
U-Boot SPL 2017.03-00838-g8ab673031c2d (Mar 22 2018 - 13:15:37)
PMIC: PFUZE100 ID=0x10
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training PASS
Training PASS
Training PASS
Training PASS
Normal Boot
Trying to boot from MMC2
baruch
Solved! Go to Solution.
Hi Diego,
Thanks for your reply.
The updated DDR script (mx8m_micron_lpddr4_3gb_2d_1600m_334m_32bit.ds) fixed the issue for me.
https://community.nxp.com/docs/DOC-340179
baruch
I apologize for the delay.
Which is the revision of your i.MX8M?
Diego.
Hi Diego,
baruch
