Use of CAAM module for bare metal application
次の代わりに検索
485件の閲覧回数
srouser526
I have a question. Is it possible to use the CAAM hardware cryptographic functions in a bare-metal application. Are there any drivers provided? I only know, that there exist drivers for linux.
Especially I like to know of it is possible, to calculate the SHA256 value for any input data in a bare-metal application.
HAB is not providing the simple calculation of a HASH value, isn't it? There are only some abstract functions to authentificate complete image.
If there exist a possibility or a driver for the hash calculation is there as well a possibility to stream the input data for the hash calculation? In the best case I like to call a function several times to stream some input data to the CAAM hash module.
Thanks.
ラベル(3)
2 返答(返信)
267件の閲覧回数
igorpadykov
Hi  stefanrombach
sdk had some simple tests: caam_blob_gen.c,caam_test.c,
however it was removed from web. For obtaining it please create
service request.
267件の閲覧回数
srouser526
Hi igorpadykov,
thanks for your reply. Yes, I could find the simple test which you mention. Like you said, the example is just to create some key blobs and to encrypt/decrypt data. Unfortunately, the example is not using a hash algorithm like the SHA. There exists no example for using it in a bare-metal application?
At least it would help me to get a sequence for the job descriptor to calculate a hash value with the SHA256. Is it possible to stream the input data for the hash calculation for example via a FIFO which is not filled at all at the start of the calculation.
stefan
