Understanding the v4l2ctl - video frame timestamps
1,057 次查看
imx_learner
I have an iMX6 transmitting live video to a Ubuntu PC as receiver. Following are my pipelines :
Tx :
imxv4l2videosrc device=/dev/video1 fps-n=30 capture-mode=4 ! \
        imxvpuenc_h264 bitrate=1000 ! \
        h264parse ! \
        rtph264pay ! \
        udpsink host=192.168.1.11 port=5001 \
        rtpbin.send_rtcp_src_0 ! udpsink port=5002 \
        udpsrc port=5005 ! rtpbin.recv_rtcp_sink_0
Rx :
udpsrc name=source port=5001 !  $CAPS !
        rtpbin.recv_rtp_sink_0 rtpbin. !  \
        rtph264depay ! \
        h264parse  ! \
        avdec_h264  ! \
        videorate  drop-only=true  ! \
        intervideosink sync=false \
        udpsrc port=5002 ! rtpbin.recv_rtcp_sink_0
        rtpbin.send_rtcp_src_0 ! udpsink port=5005 sync=false async=false
I added a probe on `udpsrc`, on the Rx side, to get notified of `GST_PAD_PROBE_TYPE_PUSH`. I understand that for every buffer push, the probe callback will be called.
Now in case I have a camera operating at 30 FPS, and transmitting this over a network, I was expecting there should be approx. 30 buffers I receive at the udpsrc (receiver side).
1. Is this understanding right?
2. Does one push-buffer correspond to 1 video frame send?
With my current debugging, I find random number of buffers being pushed in a second, for eg. the following buffers were pushed for a period of 4 seconds :  112,130,142,107 . I used the Python timer api `time.perf_counter()`, to get timestamps of each buffer in the callback function for GST_PAD_PROBE_TYPE_PUSH.
My main idea was to get the timestamp of each frame received at the udpsrc at the receiver side. How could this be achieved?
Regards.
标签 (2)
标记 (2)
887 次查看
joanxie
what problem do you have? I suggest that you can refer to the "RTP/UDP MPEGTS streaming" of linux user guide, which tell you how to set different parameters, like streaming-latency and low_latency_tolerance, and you can set do-timestamp=false
