Uboot logo an LVDS RGB 24 shows not normal
zhilinhuang
Hi ,everybody
我用的 是  imx6q   uboot  版本是    uboot-imx-imx_v2009.08_3.0.35_4.1.0
我公司现在采购了一块lvds 8 24 位的 ,分辨率为1024*768
现在的问题是,内核logo显示正常,uboot  logo 显示不正常,帮忙支持一下,谢谢。
我的具体操作如下
图片信息如下
按照规格书得出以下信息
HSPW =70
HBPD =160 -70 = 90
HFPD = 160
VSPW 10
VBPD = 23 -10 =13
VFPD = 15
内核logo 显示正常,ubootlogo 显示不正常
具体如下
修改了 uboot
第一处 board/freescale/mx6q_sabresd/mx6q_sabresd.c
static struct fb_videomode lvds_xga = {
93    "XGA", 60, 1024, 768, 15385, 90, 160, 13, 15, 70, 10, // 修改成了以上得出的结果
94     FB_SYNC_EXT,
95     FB_VMODE_NONINTERLACED,
96     0,
  97 };
第二处:
ret = ipuv3_fb_init(&lvds_xga, di, IPU_PIX_FMT_RGB24, //原来是rgb666
                          DI_PCLK_LDB, 65000000);
         if (ret)
                  puts("LCD cannot be configured\n");
修改启动bootargs
bootargs_base=setenv bootargs console=ttymxc0,115200 video=mxcfb0:dev=ldb,LDB-XGA,if=RGB24
显示如下
修改内核:
1
board-myimx6ek200.c
static struct ipuv3_fb_platform_data sabresd_fb_data[] = {
.disp_dev = "ldb",
1792     .interface_pix_fmt = IPU_PIX_FMT_RGB24,
1793     .mode_str = "LDB-XGA",
1794     //.default_bpp = 16,
1795     .default_bpp = 32,
1796     .int_clk = false,
1797      {
2,修改 linux-2.6-imx-imx_3.0.35_4.1.0/drivers/video/mxc/ldb.c
106 static struct fb_videomode ldb_modedb[] = {
107 {
108 //"LDB-WXGA", 60, 1280, 800, 14065,
109 "LDB-WXGA", 60, 1024,768 , 15385,
110 //40, 40,
111 90, 160,
112 13, 15,
113 //21, 7,
114 70, 10,
115 0,
116 FB_VMODE_NONINTERLACED,
117 FB_MODE_IS_DETAILED,},
118     {
119      "LDB-XGA", 60, 1024, 768, 15385,
120      90, 160,
121      13, 15,
122      70, 10,
123      0,
124      FB_VMODE_NONINTERLACED,      //修改
125      FB_MODE_IS_DETAILED,},
内核logo 显示正常
请问该如果修改uboot logo 正常显示  我已经研究2天了还是没有找到解决的方法
我改了一下几个参数还是没有解决,
#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define LCD_BPPLCD_COLOR16
#define CONFIG_BMP_8BPP
Rita_Wang
Hi zhilin,
You can refer to the thread Patch to support uboot logo keep from uboot to kernel for NXP Linux and Android BSP (HDMI, LCD and L...  in our community.
Dan
Note: If this post answers your question, please click the Mark Correct  button. Thank you!
Rita_Wang
Hi zhilin,
Dan
zhilinhuang
HI Dan Wang
你好,在吗,我的打了补丁后  运行 ts_calibrate  校准完成后。没有清屏返回。还是停留在老界面
好像运行qt 也一样  ctrl + C  后 界面没有清屏。这是不是补丁有问题啊。还是要修改那个地方
Have a great day
zhilinhuang
HI Dan Wang ,
thanks for your help  , 我准备尝试一下。
