UVC(USB) camera not work in Freescale Android R10.3.2 release
chenguoyin
You may counter issues when enable the uvc camera in Android R10.3.2 release package.
If so, you can apply the attach patch into myandroid/hardware/mx5x
Original Attachment has been moved to: 0001-ENGR00217321-USEPTR-feature-break-the-UVC-camera-sup.patch.zip
visakh
Hi Chen,
Now when I connect an usb webcam and try to open the default camera app it says "Camera error. Cannot connect to camera " .
The logcat -v time of those events are as follows
usb 2-1.3: new full speed USB device using fsl-ehci and address 6
01-02 00:02:28.700 I/ActivityManager( 2122): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.cam
era/.Camera } from pid 2212
01-02 00:02:28.710 I/SurfaceFlinger( 2122): mHw->getFormat() 4
01-02 00:02:28.760 I/ActivityManager( 2122): Start proc com.android.camera for activity com.android.camera/.Camera: pid=2471 uid=10025 gids={1006, 1015}
01-02 00:02:29.040 V/CameraHolder( 2471): open camera 0
01-02 00:02:29.040 I/FslCameraHAL( 2074): Face Back Camera is ov, orient is 90
01-02 00:02:29.040 I/FslCameraHAL( 2074): Face Front Camera is #, orient is 0
01-02 00:02:29.040 I/FslCameraHAL( 2074): It is the CSI device
01-02 00:02:29.040 I/FslCameraHAL( 2074): Create the software encoder
01-02 00:02:29.040 E/FslCameraHAL( 2074): The device name is not correct or the device is error
01-02 00:02:29.040 E/CameraService( 2074): Fail to open camera hardware (id=0)
01-02 00:02:29.050 E/CameraHolder( 2471): fail to connect Camera
01-02 00:02:29.050 E/CameraHolder( 2471): java.lang.RuntimeException: Fail to connect to camera service
01-02 00:02:29.050 E/CameraHolder( 2471):       at android.hardware.Camera.native_setup(Native Method)
01-02 00:02:29.050 E/CameraHolder( 2471):       at android.hardware.Camera.<init>(Camera.java:258)
01-02 00:02:29.050 E/CameraHolder( 2471):       at android.hardware.Camera.open(Camera.java:220)
01-02 00:02:29.050 E/CameraHolder( 2471):       at com.android.camera.CameraHolder.open(CameraHolder.java:124)
01-02 00:02:29.050 E/CameraHolder( 2471):       at com.android.camera.Camera.ensureCameraDevice(Camera.java:1608)
01-02 00:02:29.050 E/CameraHolder( 2471):       at com.android.camera.Camera.startPreview(Camera.java:1660)
01-02 00:02:29.050 E/CameraHolder( 2471):       at com.android.camera.Camera.access$5500(Camera.java:95)
01-02 00:02:29.050 E/CameraHolder( 2471):       at com.android.camera.Camera$3.run(Camera.java:908)
01-02 00:02:29.050 E/CameraHolder( 2471):       at java.lang.Thread.run(Thread.java:1019)
01-02 00:02:29.220 D/dalvikvm( 2471): GC_EXTERNAL_ALLOC freed 109K, 48% free 2820K/5379K, external 919K/1038K, paused 119ms
01-02 00:02:29.500 I/ActivityManager( 2122): Displayed com.android.camera/.Camera: +751ms
01-02 00:02:31.190 D/dalvikvm( 2122): GC_CONCURRENT freed 1953K, 50% free 4535K/8967K, external 9365K/11413K, paused 5ms+7ms
01-02 00:02:32.730 W/InputManagerService( 2122): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@407a00c0
Thank You
napster_k
can anybody share the orginal patch again the link is expired.
thank you
napster_k
The link to the patch is expired , is it possible to share the file again ?
Thank you
chenguoyin
please paste the output from "logcat -v time" in console.
visakh
Dear Chen,
Now I am able to connect and work one of my logitech quick cam in USB port and via android camera apk.
What did is
1. Applied the patches as you specified .
2. changed setprop backcamera as UVC and orientation to 0
Now what happening is when changing to video the apk gets force close. What should be the next step to solve this issue. Reply immediate.
chenguoyin
from the log, you still not set the backcamera to be UVC.
Be sure you set the property in init.freescale.rc
visakh
Hi Chen,
With the application of your patches and setting back-camera as UVC with 0 orientation things worked well. I found an interesting behavior when went through the testing.. They are,
1. camera app outputs "cannot connect to camera" when the output display is HDMI and has no problem when the display is VGA
2. Camera app force closes when going to video mode(When display is VGA also).
visakh
Hi Chen,
Thank You
visakh
Hello Guoyin Chen,
Does 10.4 need to apply this patch, or this things are applied by default in this build?.
I Have connected a web cam to our hardware( imx535,ref. ARD) and tried to open the camera app. which ends in a force close.
here is the Log,
usb 2-1.4: new high speed USB device using fsl-ehci and address 5
uvcvideo: Found UVC 1.00 device USB2.0 Camera (1e4e:0100)
uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
input: USB2.0 Camera as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.4/2-1.4:1.0/input/input2
Any clue, i am also working around the same now
