UUU not working it opens and then closes instantly
1,009 次查看
antonior1994
I am trying to flash an i MX 8M NANO with android. When I run the uuu_imx_android_flash the command window comes up for a second and then closes so I cannot flash my board. I added the path of uuu.exe to my environmental variables for both user and system path but it still gives me the same problem. The screen closes too fast so I cannot see if there was an error I have tried different versions of the uuu. I have my debug USB and nothing is displayed there. My board is in Download mode.
I created a new folder called uuu in my c drive and added the uuu.exe in there and the I added the following path to the user and system variables.
C:\uuu
I am running Windows 10 64 bit.
Can any one guide me on this issue?
923 次查看
igorpadykov
Hi Antonio
what android release used in the case (as not all releases support i.MX8M Nano).
supported processors can be found in Release Notes in Android documentation on
i.MX Software and Development Tools | NXP
Specific uuu requirements can be found below
also one can look at UUU.pdf   documentation
p.7 "Running environment", "FAQ"  • uuu exit silence..
