UUU can't work on iMX7D when I using the latest release
626件の閲覧回数
augustine829
Hi all,
     When I upgrade uuu into 1.4.243 offical release, it can't work on iMX7D, but it can work on iMX6SX.
I put all the log here about iMX7D:
CE Load Images for imx7d-p2 Board
PWA: P4
Board: imx7d-p2
Board SN#: aaaaaaaaa
Fixture: 0
USB Device: MX7D,SDP,3:43
reboot_ce, prot=SDP, full=False
run: tools/uuu.ubuntu -m 3:43 -t 60 firmware/ce/u-boot.imx
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.193-0-ge56424c
Success 1 Failure 0 at path 3:43
3:43 2/ 2 [Done ] SDP: done
USB Device MX7D: USB State: SDP
USB Device: Not Detected, chip=MX7D, state=FB
UIC:UIC_CE_PROBE: 1, mx6=1, mx7=0, mx6val=MX6SX,FB,3:42, mx7val=Error: CE SDP Boot Failed!
Check Boot Mode, USB Connection, Board Power,
Issue Power Cycle...
Device Probing Done.
If any body meets the same question, please share your fix.
ラベル(2)
タグ(1)
604件の閲覧回数
augustine829
Today I verify it based on 1.3.171, the uuu work. but after 1.3.191, it can not work on iMX7D
