Please refer to the Chapter 39 of the attached document. Hope it helps.
Artur
Which version of kernel are you using?
This feature has been there since i.MX kernel 3.14.52 if I am not mistaken
Did you enable CONFIG_USB_OTG_FSM option in your kernel?
Gilles.
Hi Gilles Talis,
Using kernel version 4.1.15 and the option CONFIG_USB_OTG_FSM=y is enabled .
Did you enable one of these options in the dts?
hnp-enable
srp-enable
Just changing hnp-disable to hnp-enable should do the trick.
However, the a_bus_req/a_bus_drop options do not appear there:
/sys/bus/platform/devices/ci_hdrc.0/inputs/a_bus_req
but rather here for me:
/sys/devices/soc0/soc/2100000.aips-bus/2184000.usb/ci_hdrc.0/inputs/a_bus_req
Gilles.
Hi Gilles Talis,
Yes , the below configurations are updated in the dts file,
hnp-enable
srp-enable
and the a_bus_req node is not present in the path you mentioned in the above reply.
Is there any other requirement needed in 4.1.15 kernel ?
Thanks and Regards
Shravan S
Hi Shravan S,
To my knowledge, there's no other requirement needed in 4.1.15 kernel.
Which SoC and board are you using?
thanks
Gilles.
Hi Gilles Talis,
I am able to see the nodes
as you mentioned in the previous mail.
But the role switching is not happening with my iPhone after the below command
echo 1 > /sys/devices/soc0/soc/2100000.aips-bus/2184000.usb/ci_hdrc.0/inputs/a_bus_req
I am following the procedure as per below
Linux/Documentation/usb/chipidea.txt - Linux Cross Reference - Free Electrons
The Board details : iMx6q sabre Auto infotainment board
Thanks and Regards
Shravan S
Hi Gilles Talis,
Below are the behaviour I am facing during role switching,
1) NXP board is in host mode -By default ( echo host > /sys/kernel/debug/ci.hdrc0/role )
on "lsusb" command I am able to see the devices connected = > Its a expected behaviour.
The connected B-device ( Apple iPhone ) is getting charged.
2) NXP Board is in gadget mode ( echo gadget > /sys/kernel/debug/ci.hdrc0/role )
on "lsusb" command I am not able to see the devices connected = > Its a expected behaviour.
The connected B-device ( Apple iPhone ) is not getting charged. As iPhone expects the power to be supplied from the connected device , when the iPhone is in host mode .
I am suspecting that vbus should be enabled even when the NXP device is in gadget mode .
Did some code modification (short cut way => not the proper fix) to enable to regulator to have the voltage supply in vbus in both the modes . The proper fix should be handling of gpio to enable vbus in both host and device(gadget) modes .
Even after we enable the vbus , we are not able to perform role switch , the nodes responsible for role switch (echo host > /sys/kernel/debug/ci.hdrc0/role) are updating with proper values , but we are not able to see the exact functionality of role switching.
And the documentation part of the kernel say the different nodes for the role switching as below
as you mentioned in the document
Kernel Version : 4.1.15
Thanks and Regards
Shravan S
Hi Shravan S,
Sorry for late reply.
This is beyond my knowledge. I was expecting this to work out of the box.
It is clear that something is missing, but I do not know what. It might be worth doing some debugging in the USB driver. From what I could see, the code is located in drivers/usb/chipidea/. There is a "otg_fsm.c" file, it might worth checking that the OTG state machine is implemented correctly or is not blocked in some weird state.
Sorry but I can't help more.
regards
Gilles.
