I am working on imx6q based processor board(Custom). We compiled u-boot and tried to install it on our custom board. But it's failed. But we tried a u-boot of E9 board and its loaded in our custom board's RAM. Again in that boot prompt also we are unable to give inputs to that u-boot.
I would like to know the reason why my compiled u-boot is not working on my custom board.
I am trying to install u-boot of bin file through MFG tool
Board configuration :
Imx6q
1G RAM
UART 1 debug
已解决! 转到解答。
This is because the correct usdhc settings is not done in the device tree file
Once I updated that in the device it works for me.
Hi Venkata
for new board recommended first run ddr test
https://community.freescale.com/docs/DOC-105652
then rebuild uboot with new calibration settings put in U-Boot 2009../freescale/board_name/flash_header.S file
Also as board may use different pads for peripherals, these should be also configured
properly, please check attached Porting Guide. May be recommended to check documentation on
Hello igarpadykov,
I did the DDR Test and updated the DCD values to the flash header.
And compiled the U-boot. when I load the u-boot using imx_usb ( usb loader ) to my target board.
load_size 0 bytes
load_addr 0x00000000
dcd 1
clear_dcd 0
plug 1
jump_mode 2
jump_addr 0x00000000
== end work item
loading DCD table @0x910000
<<<-232, 1024 bytes>>>
succeeded (status 0x128a8a12)
loading binary file(u-boot.imx) to 177ff400, skip=0, fsize=70c00 type=aa
<<<461824, 461824 bytes>>>
succeeded (status 0x88888888)
jumping to 0x177ff400
But, I load another u-boot of my ready made ( waveshares' E9 Board ) board, then it is showing the u-boot prompt
imx_usb loader log
Interface 0 claimed
HAB security state: development mode (0x56787856)
== work item
filename u-boot-mx6q-sabresd.bin
load_size 0 bytes
dcd 1
clear_dcd 0
plug 1
jump_mode 2
== end work item
<<<-352, 1024 bytes>>>
loading binary file(u-boot-mx6q-sabresd.bin) to 27800000, skip=0, fsize=27864 type=aa
<<<161892, 162816 bytes>>>
jumping to 0x27800400
U-BOOT Log
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63015 [POR ]
Boot Device: NOR
I2C: ready
DRAM: 1 GB
MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
Using default environment
In: serial
Out: serial
Err: serial
i2c: I2C3 SDA is low, start i2c recovery...
I2C3 Recovery failed, I2C1 SDA still low!!!
Net: got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
Hit any key to stop autoboot: 0
Wrong Image Format for bootm command
ERROR: can't get kernel image!
MX6Q SABRESD-MFG U-Boot >
I am using 1 GB RAM.. And I am using the sabresd board as reference.
I have not change these variables
But, when my compiled u-boot is jumping to 0x177ff400 and there is not console log.
I am doing anything wrong ?
if your board works well with waveshares' E9 Board, then it is based on
that design. Uboot for i.MX6Q-SABRESD may not work for it,it should be customized
based on E9 Board shematic. U-Boot 2009 works with old L3.0.35 BSPs which
now not supported by nxp. Sources can be found on
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/?h=imx_3.0.35_4.1.0
LTIB Archives - Boundary Devices
~igor
This is my imx_usb loader log when I try to load E9 Board's bin file
On Console I am getting this log
U-Boot 2009.08-dirty (Nov 27 2013 - 10:51:14)
CPU: Freescale i.MX6 family TO1.5 at 792 MHz
Thermal sensor with ratio = 184
Temperature: 38 C, calibration data 0x58e50369
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock : 66000000Hz
ipg per clock : 66000000Hz
uart clock : 80000000Hz
cspi clock : 60000000Hz
ahb clock : 132000000Hz
axi clock : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock : 528000000Hz
usdhc1 clock : 198000000Hz
usdhc2 clock : 198000000Hz
usdhc3 clock : 198000000Hz
usdhc4 clock : 198000000Hz
nfc clock : 24000000Hz
Boot Device: NOR
I2C: ready
DRAM: 1 GB
In: serial
Out: serial
Err: serial
FEC0 [PRIME]
After this I am unable to give any boot commands from console.
Is this any u-boot version issue or am I doing any wrong in u-boot compilation ?
When I try to load a u-boot.bin file which was compiled as mx6qsarbesd_config is giviing the following error
== work item
filename ../N-board/u-boot/u-boot.bin
load_size 0 bytes
dcd 1
clear_dcd 0
plug 1
jump_mode 2
== end work item
unknown load address
DoIRomDownload failed, err=-3
any issue in the boot compilation ?
