Two displays support via HDMI and MIPI-DSI
搜索替代
1,689 次查看
dmitrykonyshev
Is it possible to use HDMI and MIPI-DSI at the same time to create a two-display system? It doesn't seem to be explicitly stated in the documentation. In the sample EVK device trees with MIPI-DSI (fsl-imx8mq-evk-lcdif-rm67191.dts and fsl-imx8mq-evk-lcdif-adv7535.dts) the HDMI is disabled. Is it because it's impossible to use both in parallel or there's another reason for this?
Dmitry
标记 (2)
924 次查看
felixradensky
Hi Dmitry,
The relevant DTS file is fsl-imx8mq-evk-dual-display.dts. The following article may be helpful: How to use dual display on i.MX8 including 4k decoding - i.MXDev Blog
Felix.
925 次查看
felixradensky
Hi Dmitry,
Felix.
924 次查看
dmitrykonyshev
Thank you, Felix!
