Touch control?
Touch control?
911 次查看
HaiDangSon
Hi every one.
I have some trouble about the touch lcd.
The freescale's lcd is seiko 43WVFIG. That's work good.
My lcd is ampire AM-800480L with the same resolution but the size is bigger, that's display well.
Both of them have the touch panel with 4 line connect to imx53.
I use the seiko driver to control ampire.I can touch the panel of ampire but the imx not get right position ( error about 2-3mm, I just measure by my eye).
I don't familliar with os system, that's I can't understand how it works.
My question is:
- I want to debug the position when I touch to the panel of LCD.
What file I need to modify to printf the x-y position to visual 2008 (in debug mode)?
After that I want to modify to make imx53 understand right position.
- If possible, can you explain what OS system work? Does it like the microcontroller work in file main.c and if interrupt happen that jump to interrupt function?
Thanks in advance.
标记 (2)
0 回复数
