To find the root cause of i.MX6Q IPU error interrupt.
6,926 次查看
satoshishimoda
Senior Contributor I
Hi community,
I have a question about i.MX6Q IPU.
Please see Table 37-35 in IMX6DQRM Rev.1.
Sometimes IPU_INT_STAT5[0] and IPU_INT_STAT10[0] is occurred on a custom board.
These interrupts seem that these are generated by input data from CSI, so we checked whether input data from camera is over the i.MX6Q CSI spec, but the input data is smaller than the maximum spec of CSI sufficiently. (camera data: 1920x1080@30fps BT.1120)
And they have already set IPUx_HSP_CLK_ROOT to large value adequately (264MHz), so we think the root cause is not performance of CSI.
In this case, could you give me a advice what should we check to find root cause?
(e.g. we should check the signal integrity of camera data, IPU output IPU_INT_STAT5[0] or IPU_INT_STAT10[0] if memory bandwitdh is not sufficient, etc..)
For your information, IPU is used to output 320x240 10fps also.
Satoshi Shimoda
标签 (2)
标记 (1)
10 回复数
3,822 次查看
igorpadykov
Hi Satoshi,
you are right, this is performance issue as described in link below
https://community.freescale.com/message/320553#320553
Please understand that this is specific application issue -
that is, this depends on customers configuration.
Issue may be solved by finding source of bandwidth limitation:
you can start test with SDK, then with Linux min. configuration.
Then, adding drivers one by one, you can find when error will start to appear:
this will be source of this error.
chip
3,822 次查看
satoshishimoda
Hi chipexpert,
Thank you for your reply.
Table 37-35 shows these error are occurred SMFC or IDMAC, so I guessed this is camera input performance issue.
According to your reply, are these error "IPU_INT_STAT5[0] and "IPU_INT_STAT10[0]" also occurred by not only camera input performance but also system memory bandwidth?
Satoshi Shimoda
3,822 次查看
igorpadykov
Hi Satoshi,
yes I agree with you.
One can try to reserve more memory to IPU tasks
https://community.freescale.com/docs/DOC-93591
or use more new 3.10.17 kernel which has better memory
management
L3.10.17_1.0.0_IMX6QDLS_BUNDLE
chip
3,822 次查看
satoshishimoda
Hi chip,
We changed the resolution of camera input from 1080p to VGA to reduce load for memory.
But these error have remained yet.
So we think these error are not performance issue.
Do you think so?
For your information, the following messages are log when the error was occurred.
[pattern 1]
ERROR: v4l2 capture: mxc_v4l_dqueue() interrupt received
Segmentation fault
imx-ipuv3 imx-ipuv3.0: IPU Warning - IPU_INT_STAT_10 = 0x00000001
[pattern 2]
Segmentation fault
[pattern 3]
VPU interrupt received.
Segmentation fault
We can find "Segmentation fault" in all patterns.
So we doubt it as the root cause.
Could you let me know what module output "Segmentation fault" and when output it?
Satoshi Shimoda
3,822 次查看
satoshishimoda
If you can, could you let me know the root cause of the above 3 patterns error?
3,822 次查看
igorpadykov
Hi Satoshi,
to answer your question
it is necessary to check this issue on our side.
Could you tell steps, how this issue can be reproduced
on Freescale reference board with Freescale BSPs ?
BTW had you chance to try new 3.10.17 kernel
which has much better memory management ?
chip
3,822 次查看
satoshishimoda
Hi chip,
Unfortunately, we cannot reproduce this issue with SABRE board because SABRE board cannot receive BT.1120.
So could you reply to our simple question one by one to investigate what is the root cause of this issue?
At first,  our first simple question is "Could you let me know what module output "Segmentation fault" and when output it?"
Satoshi Shimoda
3,822 次查看
igorpadykov
Hi Satoshi,
regarding "what module output "Segmentation fault" and when output it" -
it outputs by IPU, when - please look below
Segmentation fault - Wikipedia, the free encyclopedia
Could you post this issue  to meta-fsl-arm mailing list, so that someone familiar with
IPU "Segmentation fault" errors could try to assist you.
https://lists.yoctoproject.org/listinfo/meta-freescale
Also did you check below patch
Support BT1120 progressive mode in Mx6Q
chip
3,822 次查看
satoshishimoda
Hi chip,
If you know, could you let me know what source code in BSP (L3.0.35_4.1.0) output the "Segmentation fault" also?
Sorry, I don't know what is the mailing list and don't know how to use.
For your information, out partner have already applied  the below patch.
Satoshi Shimoda
3,822 次查看
igorpadykov
Hi Satoshi,
when one goes on link below, there you will be prompted to enter e-mail
Regarding :
"If you know, could you let me know what source code in BSP (L3.0.35_4.1.0) output the
"Segmentation fault" also?"
- sorry, it is impossible to say in which on many thousands of Linux instructions
this error happens.
Actually, as you correctly noted, this case is not supported in Freescale Linux BSPs
and it is not possible to reproduce it on Freescale boards.
You can post issue on this mailing list, there
i.MX developers are working and they know many typical errors, they may help.
Alternatively you can apply to FPS
http://cache.freescale.com/files/training/doc/ftf/2014/FTF-SDS-F0251.pdf
chip
