The problem about register configuration of AR0234
1,333件の閲覧回数
jax_wang
I am using AR0234 to learn driver develop, and now the sensor has alread to output 10bit image, but The 8-bits is not work successfully.
SO,
Do somebody know how to set the register of ar0234 to output 8bit raw image.
Thank you.
タグ(1)
1,294件の閲覧回数
jax_wang
Hi, khang_letruong
The key is register 0x3354, its value should be 0x2a, but the RR is show 0x32 for 8-bit.
5 返答(返信)
1,317件の閲覧回数
khang_letruong
Senior Contributor III
Hi @jax_wang ,
Register 0x31AC should be 0x0A08 (default is 0x0A0A)
K.
1,295件の閲覧回数
jax_wang
Hi, khang_letruong
1,307件の閲覧回数
jax_wang
Hi,Khang_letruong,
Firstly, thanks your reply.
I have changed the value of 0x31AC to 0x0A08, but it still occurs error. I message to you, could you help me check it?
Thank you.
1,305件の閲覧回数
khang_letruong
Hi @jax_wang ,
I shared you the description of the sensor's register relevant to 8/10-bit Bayer output. You might also need full datasheet from vendor for checking other registers as well.
K
1,320件の閲覧回数
joanxie
if you need to know how to configure AR0234 camera to support 8bits, you need consult from Onsemi, if you use it on the imx8mp board, current bsp supports this format already
