Support exFAT filing system on SD card.
次の代わりに検索
482件の閲覧回数
divyeshmarne0
Hi Team,
  1. We have imx8mm device with Android 11 code. Added support for SD card in fstab entry.
  2. Could you please help here to support the exFat filing system on SD cards.
also we need following path to locate external storage (SDCARD) in adb shell:
  1. /sdcard/
Currently it is points to the internal memory which is android file system.
We need /sdcard path as a /sdcard/<Sdcard_name_byUser>
Divyesh
3 返答(返信)
441件の閲覧回数
divyeshmarne0
Hi @joanxie ,
We have added support for exfat in Android 11 code base. Now exfat formatted SDcard is supporting.
But we are not able to create folder in /sdcard folder. We need External sdcard points to the /sdcard/ClubCar directory. But in current implementation it is pointing to internal storage of device. need to change path to point External sdcard. Could you please help here ?
451件の閲覧回数
divyeshmarne0
Hi @joanxie ,
I tried to format SDcard with exfat and it is working through adb shell :
evk_8mm:/ # mkfs.exfat /dev/block/mmcblk1p1
mkexfatfs 1.3.0
Creating... done.
Flushing... done.
File system created successfully.
After executing these commands, I can see type=exfat.
BUT I need default format exfat without any commands through adb shell...
459件の閲覧回数
joanxie
