We are trying to stream 1080p 30FPS from i.MX6 to X86 platform. We are us using UVC Camera module connected to i.MX6 board and streaming data over Wi-Fi to Laptop (X86 Platform).
USB 2.0 Camera supports 1080p 30FPS, we are able to capture the video and verified that camera is capable of streaming 30FPS with 1080p resolution by recording the video using the below command.
i.MX6 ( Server):
$ gst-launch-1.0 v4l2src device=/dev/video0 ! image/jpeg, width=1280, height=720, framerate=30/1 ! jpegdec ! videoscale ! videoconvert ! queue !
X86 Platform ( Laptop):
$ gst-launch-1.0 -vc udpsrc port=5000 ! application/x-rtp, payload=96 ! rtpjitterbuffer ! rtph264depay ! avdec_h264 ! fpsdisplaysink sync=false async=false
When we try to sync 1080p by modifying the above command we are getting dropped frame rate. As per data sheet USB Camera supports MJPEG @30FPS and YUV upto 5FPS for 1080p resolution.
We are trying to achieve 1080p with 30FPS with minimum latency, can you please guide us to achieve the same.
Thanks in Advance.
