I am working with IMX8M Mini EVK and yocto project build details:
Build Configuration:
BB_VERSION = "1.38.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-16.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mmevk"
DISTRO = "fsl-imx-xwayland"
DISTRO_VERSION = "4.14-sumo"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
We have interfaced another SoC to iMX8MM EVK, the firmware binary will be loaded by iMX8MM to SoC.
the firmware.bin file i placed in the /lib/firmware/ directory.
imx-yocto-bsp/Build-xwayland-imx8mmevk/tmp/work/imx8mmevk-poky-linux/fsl-image-validation-imx/1.0-r0/rootfs/lib/firmware/
After this i bitbake the distribution and it generated the sdcard image. i flashed the image and found that the firmware.bin file is not present in the /lib/firmware/
I think i need to do follow some extra procedure to add the firmware binary to /lib/firmware/.
Could you please point me to the proper steps or example any.
Thank you,
Sreedhar
Solved! Go to Solution.
Hi Sreedhar,
Here you can find detailed on hwo to add files to root file system:
L-813e_5_Yocto_Reference_Manual | PHYTEC
Hope it can help you!
Have a nice day!
B.R,
Weidong
Hi Sreedhar,
Have a nice day!
B.R,
Weidong
Thank you Weidong !!
