Share GPIO bank on i.MX7 (read-only)
330 次查看
rfet
We would like to share a GPIO bank on i.MX7 between A7 (running on Linux) and M4 (running on FreeRTOS). Knowing that simultaneous writes on GPIOs (without a running RDC under Linux) could lead to collisions, we would write/read GPIOs with A7-core and only read GPIOs with M4-core.
Is there also potential for collision due to uncoordinated read-accesses on same GPIO-Bank?
R. Frei
311 次查看
kef2
Senior Contributor IV
Only read accesses on one side should be enough, unless you are going to use GPIO interrupts on RO side. For interrupts you should disable whole GPIO peripheral on Linux side.
Edward
