Serial console does not display properly for Android 4.4 BSP
次の代わりに検索
709件の閲覧回数
changyuheng
Hello All:
Default console debug port was set in UART1 for mother board, but  our customer IMX6 board was setting for UART3.
The console shows random unstable since turn UART1 to UART3 as follow:
root@sabresd_6dq:/ #
root@sabresd_6dq:/ # UV
                                            UV
;kdlsrequest_suspend_state: wakeup (3->0) at 26127490005 (2015-01-27 02:54:39.635235336 UTC)
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:04, irq=-1)
ADDRCONF(NETDEV_UP): eth0: link is not ready
acc_open
acc_release
ehci_fsl_bus_resume begins, DR
US 921600
I have no idea to fix this issue, modify code as follow:
arch/arm/configs/imx6_android_defconfig:
CONFIG_CMDLINE="noinitrd console=ttymxc2,115200 root=/dev/mtdblock2 rw rootfstype=jffs2 ip=off
arch/arm/mach-mx6/board-mx6q_sabresd.c:
static void __init mx6_sabresd_timer_init(void)
#endif
        mx6_clocks_init(32768, 24000000, 0, 0);
-       uart_clk = clk_get_sys("imx-uart.0", NULL);
-       early_console_setup(UART1_BASE_ADDR, uart_clk);
+       uart_clk = clk_get_sys("imx-uart.2", NULL);
+       early_console_setup(UART3_BASE_ADDR, uart_clk);
arch/arm/mach-mx6/board-mx6q_sabresd.h:
    MX6Q_PAD_SD4_CLK__UART3_RXD,
    MX6Q_PAD_SD4_CMD__UART3_TXD,
this way is work for ubuntu BSP, so I don't know why android OS has this problem.
Please kindly teach me how to fix it!
Thanks.
ラベル(2)
タグ(1)
241件の閲覧回数
albertlim
Thanks Jimmy. The UART setting is fine. I've found the problem, some driver is using the UART3 and I have manage to disable it.
4 返答(返信)
242件の閲覧回数
albertlim
241件の閲覧回数
albertlim
Hi Public Account,
I am seeing these coming out from UART 3. Have you resolved your problem. I5ts very much appreciated if your could give me some hint
UV
     UV
          UV
               US 921600
                                   US 921600
                                                       US 921600
I would need to know where these came from and how to disable them . The baud rate is 115.2kbps. These looks to me like some command sent out from some driver
Thanks a bunc
Albert
241件の閲覧回数
jimmychan
241件の閲覧回数
jimmychan
Please see this.
https://community.freescale.com/thread/308092
please check init.rc.
