Hi !
In my secure OS/secure monitor configuration, I'd like to prevent any access from the Normal World to the SRC component, to prevent Linux to reset a core in secure mode.
My first idea was to use the CSU, but unfortunately that means to also remove access to the whole power group (CCM, GPC, ...). Then I turned to the AIPSTZ and saw that the SRC as a single slot !
However I don't see any way to prevent access to the AIPSTZ configuration from the NW (nothing in it, and nothing in the CSU).
Is it possible to prevent access from the normal world to both AIPSTZ, and if it is, how would I do it ?
Best,
V.
Solved! Go to Solution.
Hi Vincent
I think your understanding is right, there is no way to prevent access to the
AIPSTZ configuration from the NW.
Hi Vincent
Thank you once again for clarifying that. I'll use the CSU to protect the SRC and will port the other PM group drivers then.
Best,
V.
