Sabre Board for Smart Devices question?
次の代わりに検索
817件の閲覧回数
sparkyee
    I just recieved my Sabre Board for Smart Devices. I have gotten the
board to boot to a serial console OK. I ahve also hooked up a HDMI
monitor and can see ANDROID booting up to a start screen with a
clock and lock symbol showing. I have tried to get a mouse and/or keyboard
to work on the other USBOTG port but they don't see to have power. I
am trying to unlock the ANDROID screen to see other APPS.  I also
tried putting a mouse on the Debug USB/serial emulator port with no
success. How do I power up these peripherals??
Thanks a Lot!
Larry
ラベル(2)
512件の閲覧回数
weidong_sun
Hello,Larry,
     By default, USB OTG works as device, It's power is not opened. If you want it to work as a host, you do a little modification in BSP source code. open linux/arch/arm/mach-mx6/board-mx6q_sabresd.c,and find function "static void __init imx6q_sabresd_init_usb(void)", in this function, open USB OTG POWER. see following:
//gpio_direction_output(SABRESD_USB_OTG_PWR, 0);
gpio_direction_output(SABRESD_USB_OTG_PWR, 1);
then recompile linux kernel and burn it into iNAND FLASH or SD card , boot your board, USB OTG can be used as HOST, your mouse can be used.
Reards,
Weidong
3 返答(返信)
512件の閲覧回数
Yuri
I tried to connect a USB mouse on the SDP with the recent Android (13.4.1) demo image - it works.
512件の閲覧回数
weidong_sun
Hello,Yuri & Larry,
     The BSP I checked is linux(L3.0_1.1.0_121218 Version),So Thank you for your supplying status of OTG on android.
Weidong
513件の閲覧回数
weidong_sun
Hello,Larry,
Reards,
Weidong
