SPI slave configuration in iMX8QM
ajmalmali
We are using imx8qm in our custom hardware,with linux kernel version :5.4.24. Here SPI0 is to be configured as slave which communicates with a RH850 processor (master).In imx8qm spi0 is configured with spi mode as 1 and 1MHz master clock (tried with 2MHz clock also)
Spi connections is as below:
SPI0 Master
MOSI <------------------ M0SI
MISO ------------------> MISO
SS <------------------ SS
SCLK <------------------ SCLK
we made the following update in the dts file:
lpspi0 {
#address-cells = <1>;
#size-cells = <0>;
fsl,spi-num-chipselects = <1>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_lpspi0 &pinctrl_lpspi0_cs>;
spi-slave;
status = "okay";
spidev0: slave@0 {
reg = <0>;
compatible = "rohm,dh2228fv";
spi-max-frequency = <10000000>;
status = "okay";
pinctrl_lpspi0: lpspi0grp {
fsl,pins = <
IMX8QM_SPI0_SCK_DMA_SPI0_SCK 0x0600004c
IMX8QM_SPI0_SDO_DMA_SPI0_SDO 0x0600004c
IMX8QM_SPI0_SDI_DMA_SPI0_SDI 0x0600004c
IMX8QM_SPI0_CS0_DMA_SPI0_CS0 0x0600004c
pinctrl_lpspi0_cs: lpspi0cs {
fsl,pins = <
IMX8QM_SPI0_CS0_LSIO_GPIO3_IO05 0x21
when we try to recieve 2 bytes of data (from RH850), its getting hang. Can you check whether the dts configuration is correct or not.
Thanks in Advance!
AldoG
Please try with the following dts settings for lpspi0 as slave:
lpspi0 {
#address-cells = <0>;
pinctrl-0 = <&pinctrl_lpspi0>;
spi-slave;
status = "okay";
fsl,pins = <
I have followed this 2 dts as reference so you may take a look at them as well:
https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm64/boot/dts/freescale/imx8qm-lpddr...
Aldo.
ajmalmali
Hi @AldoG ,
Thanks for the support.
I tried the reference configuration you have shared.
After integrating the updated node. I could not find spidev in "/dev" folder.
With my previous changes(dts) I was able to list the spidev in /dev folder.
Can you please check and support me?
Please revert if more details are required.
REgards
Ajmal
AldoG
Sorry for the confusion, yes you may add the spidev node to it
lpspi0 {
spi-slave;
status = "okay";
spidev0: slave@0 {
reg = <0>;
status = "okay";
Aldo.
