SPI interface with IMX6 solo processor
Search instead for
subhashreechand
Hello All,
I want to interface MCP2515 (CAN Controller) with IMX6 solo processor via SPI .
what is the procedure to do this?
Can anyone help me on this ?
mtx512
Contributor V
The i.mx6 SoloX has a built in CAN controller (Flexcan) so using the MCP2515 is overkill. You can use a CAN transceiver eg SN65HVD232 with Flexcan.
joanxie
subhashreechand
Hello Joan Xie ,
Thanks for the reply .
But that post speaks about the Kernel version.
I am trying to write the  code , build it and copy the bin  to the SD card and then flash the bin to the processor.
My question : what are the steps to code to make the MCP2515 transmit/receive a CAN signal to the i.MX6 SoloX processor ?
